6.0 fuel issue
Old Nov 7, 2017 | 11:42 AM
  #61
Sparky83's Avatar
Sparky83
Originally Posted by coloradojeep1
I'm still thinking about doing the spool valves. It doesn't look complicated except for the correct torque when putting back together. If the bolt were to break I guess it would mean a new injector. I will be changing the rings and brass washer for sure. Thanks again.
Stiction can be more thought of like a sticky valve when the systems all cold.. it wont really cause it to not start but will cause it to run rough until everything warms up..
again make sure that if you pull the valve that it goes back in the same direction it comes out... there is a right and a wrong orientation for it.
Old Nov 7, 2017 | 11:45 AM
  #62
speakerfritz's Avatar
speakerfritz
You ask a moderator to move this thread to the 6.0 section of the diesel forum
lots of folks who have been down this path there
good luck.
Old Nov 7, 2017 | 12:43 PM
  #63
coloradojeep1's Avatar
coloradojeep1
6.0 fuel delivery
Sparky83---I'm looking at my injector sleeves and am wondering if they are OK. I see some rust surfaces in 4 and 6. How bad can these sleeves get before they need to be exchanged? I need to buy a better flashlight to get better pics of these. Too bad they don't have incandescent light bulbs anymore as it is difficult to see with a drop light with the newer style light bulbs. I will post these pics later. I guess they want to move my thread to another site. Not sure if they do it or I have to request this. Thanks again.
Old Nov 7, 2017 | 12:44 PM
  #64
coloradojeep1
6.0 fuel delivery
good luck.
Speakerfritz--not sure how to do that???
Old Nov 7, 2017 | 12:54 PM
  #65
Sparky83's Avatar
Sparky83
if your referring to the seat cups at the bottom of the heads, they shouldnt be rusting at all... if your seeing rust there it means your getting water down in there somehow.. most likely a coolant leak... but sometimes if theres enough water in the fuel itll cause it to when its blown back through via the poor copper crush seal at the tips of the injectors.. either scenario is not very good.. sloppy mechanics could have left the engine open for a long period of time allowing rain to get in there.. but would be hard to tell if that was a cause or not..
if its just light surface rust, a wire bore brush similar to a battery terminal cleaner could take care of it.. just make sure to really clean the dust out before seating the injector back in.. if its heavy you may need to have them replaced..
Old Nov 7, 2017 | 02:04 PM
  #66
coloradojeep1
I went out with a better flashlight to look down the injector holes and the color i see is oil. Ran paper towels down each tube and cleaned up pretty nice. Nothing is down in the cups and the brassy looking color was way up by the clamp. Think i'll clean a little more and vacuum out the holes before i change the oil. Wrote the monitor to move my thread to 6.0 engine forum. Hope to see you there. Thanks for everything.
Old Nov 8, 2017 | 06:35 PM
  #67
coloradojeep1
I received my o ring kits from Alliant today and am ready to install these parts on my 6.0 injectors. Question--the copper ring that goes on the bottom has different protrusions on each side. One side has a protrusion in the center and the other side has a protrusion around the perimeter. Which side slides onto the injector first? Hope someone knows this because I couldn't find a video that shows this clearly. Thanks
Old Nov 8, 2017 | 07:06 PM
  #68
FiznUKa's Avatar
FiznUKa
It doesnt matter which way it goes but if I remember the protrusion around the perimeter went towards the cup. When I had a new injector from ford that’s the way they had it.
Remember when you torque the injectors (26 ftlbs) remove all the oil from the bolt hole in the head otherwise you won’t get an accurate value. Lube the orings with clean oil and install. Before you install the oil rail pour clean oil into the top of the injectors so the top oring doesn’t get cut. Install the rail as evenly as possible to avoid cutting the orings it will kind of snap in place.
Old Nov 8, 2017 | 07:53 PM
  #69
coloradojeep1
6.0 fuel delivery
Thanks --one question though. Not sure what you mean by pouring oil into the top of the injector? Are you saying to pour oil into the very top where the o ring is held in with the C clip? I am changing the o ring in the top of each injector because in my opinion when I attached each injector to the rail it was a snug fit but watched a video where just the o ring is changed without removing the clip and this made for a better more snug fit. Doesn't look to difficult. Anyway, fill the chamber with new oil before installing the rail. Think I got it. Thanks
Old Nov 8, 2017 | 10:12 PM
  #70
FiznUKa's Avatar
FiznUKa
Yes pour oil or use a syringe where the top oring goes it doesn’t take much just helps slide the rail home without damage to the rings. Be certain when the top orings are changed they are fully seated in the groove and the snap ring is on top. With the install use a blunt plastic pick or small water color brush handle.
If I haven’t said it enough DONT KNICK AN ORING or you’ll be doing it again.
Old Nov 17, 2017 | 06:19 PM
  #71
coloradojeep1
6.0 fuel delivery
Got the drivers side done today and started on the passenger side also. Ran into two problems. What tool exactly is used to get to the bottom 30 torx bolts on the oil rail where the blower box is situated? I see one guy removed the cover for the blower and another guy uses a stubby 1/4" drive torx. I also see allen wrench style torx and wonder if these fit in there? Also pulled out my dummy plug and stand pipe. The stand pipe top came out but not the bottom of the stand pipe. How do I retrieve the other half of the stand pipe? Thanks
Old Nov 17, 2017 | 07:44 PM
  #72
FiznUKa's Avatar
FiznUKa
Use a small torx bit about an inch long and use either a 1/4" end wrench or a 1/4" ratchet wrench just keep it straight and make sure the bit is fully inserted into the bolt. As for the standpipe you can leave it until the rail comes off then use a needle nose and wiggle. When you put the new standpipe back in it's easier to split it apart and insert the long end in then put it back together again then torque it. I'll post pics of what I use when I get home
Old Nov 19, 2017 | 07:10 PM
  #73
coloradojeep1
6.0 fuel
OK--I got the 1/4" ratchet wrench and duct taped the torx to it and got the last two bolts out of the oil rail. A lot easier than removing the fan box. Thanks for that. Another weird thing. The injectors on the passenger side have different nuts for the spool valve than the driver side did. There are three injectors without any writing on them but injector number 1 has writing on it. I'll include pics to see if anyone knows if these were replaced with after market injectors. The injectors on the drivers side had a single style nut on the spool valve bolt and the passenger side has a one piece double nut configuration with a washer attached. Also, to remove my stand pipe I had to place a crow bar on the wrench and hit it with a hammer to loosen it. The stand pipe did come apart and am wondering if this is why I have bubbles on the bubble test. Hope someone can tell me if I have aftermarket injectors and why only one of the injectors has writing on it. Thanks again. Pics to follow.
Old Nov 20, 2017 | 03:42 PM
  #74
coloradojeep1
finished re-ringing the passenger side injectors and installed new dummy plug and stand pipe. Still wont start. No bubbles now on the bubble test. Cycled the key 6 times. Fuel pressure jumps right to 60. Thinking something electrical is going on. Smoke coming out of exhaust while turning over. All gauge readings are correct as before I started this project. I have a large ground wire that has been cut. It is attached to the fire wall as shown in pic. This is right above the heater blower on passenger side. Anyone else out there have this cable and where does it go? Have lots of squirrels around here and am finding sunflower seeds on top of engine. Hope someone can help me out here. Thanks
Old Nov 20, 2017 | 04:06 PM
  #75
FiznUKa's Avatar
FiznUKa
That wire is the ground strap it goes to the block on the ps rear of the head. Pull the ficm relay while you are cranking the engine over. It's going to take quite a bit of cranking for the oil pressure to come up. You drained both oil rails and the injectors so it's needs to fill everything with oil again and build pressure. Watch your ICP pressure and once it hits 500 put the relay back in and it should fire. Keep the batteries on a charger while cranking.
