6.0 fuel issue
on
I programed the scan gauge for ICP voltage (ICV). With cable connected I have a key on reading of .23v. With cable connected and cranking I have a reading of 1.94v. With cable disconnected I have 0 volts both cranking and with key on and a no start. Hope this helps?
Do you have any codes? What are you using for a data reader?
It’s also starting with starting fluid because of the high compression.
he is using a SGII... which is terrible for codes...
Another thought is air getting in the lines. Drain the fuel bowl with a turkey baster (or something) and have someone turn the key on while you watch the fuel bowl fill up (dont let it over-flow).
Once its full use the starter wire on the pass fender to crank the motor... look for bubbles.
Richard
Richard
6.0 fuel delivery
That looks better with the readings so you are building good ICP pressure. If you have fuel getting to the upper fuel bowl ther should be enough pressure to start and idle. Next we need to look at the FICM power both main and logic and check for FICM sync.
6.0 fuel delivery
Richard
Richard
6.0 fuel delivery
Richard--I emptied the fuel bowl and did exactly as you said but since then I put in a different fuel pump so will do this again tomorrow. I have 3/4 tank of fuel but when I cycle the key I hear gurgling in the fuel tank. So, tomorrow I will be taking the top of the tank off and check the pick up. Someone mentioned that I should do this. Worth a shot I guess. Thanks
6.0 fuel delivery
I got this one.... I haven't used it though. I got an IDS clone just after it arrived.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#28
I got the Chinese clone so it's hacked software. a bit of a pain to use sometimes if it misbehaves and you really need a laptop dedicated to nothing else.
The only thing IDS does (IIRC) that no others can do is an uncompensated injector balance test.
SGII does well for monitoring PIDs but apparently it cannot pull codes very well... I am not 100% sure what that means but a lot of people say it. I wonder if it cannot read all the modules or it cant see non-active codes.
You can get the knock off IDS for $200-$300 but you have to setup the laptop. I am an IT guy and it took me a while.
Richard
Richard
#29
6.0 fuel delivery
Richard
Richard
#30
on
With ForScan you can run diagnostics tests, read codes for all the modules abs,trans,pcm, etc. you can also watch multiple PID’s at the same time and disable injectors run the VGT control etc. I have a SGII that I use as a daily monitor and use ForScan for running codes and messing around with. I also use ForScan lite and a WiFi adapter for the times I don’t have the laptop. They do have ForScan lite for android and iOS but will need a WiFi adapter for iOS and a Bluetooth elm adapter for android.
This is the elm adapter I use with the laptop
