Glow plug controller keeps clicking
Old Oct 25, 2017 | 02:15 PM
Samsf350's Avatar
Samsf350
I have a 93 f350 I replaced the glow plugs and the controller and it still keeps clicking. The wait to start light is on for about a second and goes off which it doesn’t give it time to heat up the plugs. The new plugs have ohms at .6 on 2 of them and the rest are at .9. If you all have any advice please let me know. I’ve been checking every thread I can find and nothing is fitting what is happening.
Old Oct 25, 2017 | 03:08 PM
madpogue's Avatar
madpogue
What keeps clicking? Starter relay? GPR? GP controller? Conflicting info in the OP.
Old Oct 25, 2017 | 05:58 PM
Samsf350's Avatar
Samsf350
Sorry the glow plug controller keeps clicking.
Old Oct 26, 2017 | 07:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
what brand glow plugs did you put in it?
if anything but motorcraft/beru plugs, they are most likely burned out already.
Old Oct 26, 2017 | 10:07 AM
Samsf350's Avatar
Samsf350
I used autolite
Old Oct 26, 2017 | 03:19 PM
tjc transport
i ain't rite
GET THEM OUT OF THERE NOW!!!!
autocrap glow plugs are the absolute worst there is out there, and should be against the law to sell to ford owners.
they usually burn out after the first application of power.
and sometimes the tips swell up resulting in having to remove the head off the engine to get the burned out plug out of the head.
you want motrocraft/beru ZD-9 glow plugs ONLY!!
you can get them from rock auto for under $10 each.
sometimes you can find them on ebay for a good deal too.
don't let the auto parts store counter monkey tell you any different, nothing works in these trucks except motorcraft/beru ZD-9 glow plugs.
Old Oct 26, 2017 | 05:46 PM
Samsf350's Avatar
Samsf350
Thanks! I’ll take them out and get those I’ll let you know how it works out for me.
Old Oct 26, 2017 | 05:59 PM
tjc transport
i ain't rite
if you can not let the truck sit until you get the new plugs, disconnect the power going to the glow plug controller and tape the wires off real good.
then use a slight whiff of starting fluid to start it up when cold.
by a slight whiff, i mean like a 1/2 to one second spray in the intake before starting. that should be more than enough to get it to fire up.
the reason for disconnecting power is so if one or two of the glow plugs is still working it will ignite the starting fluid before the engine wants it to and can cause problems.
Old Nov 5, 2017 | 08:54 PM
Samsf350's Avatar
Samsf350
That was the issue thank you for the help!
Old Nov 6, 2017 | 08:18 AM
tjc transport
i ain't rite
good to hear ya got it fixed!!
pjcat
Feb 2, 2015 08:41 PM
66f100prostreet
Nov 14, 2009 09:35 PM
countrysF250
17
Nov 2, 2007 08:32 AM
Diesel Fiend
Jul 3, 2007 12:12 AM
Ace of Spades
Aug 8, 2004 01:29 AM
