Sponsored by: Real Truck
Programming heated seats
Old Oct 24, 2017 | 07:14 PM
Bugzilla46310's Avatar
Bugzilla46310
Is there a way to program the heated seats so they come on when you start the truck with the key fob? Would be a nice feature in the winter! Thanks
Old Oct 24, 2017 | 07:40 PM
Just Strokin's Avatar
Just Strokin
Check page 116 of your owner's manual. It tells the requirements for seats to heat or cool
REMOTE START (If Equipped)
The remote start feature allows you to pre-condition the interior of your vehicle.
The climate control system works to achieve comfort according to your previous
settings.
Note: You cannot adjust the system during remote start operation.
Turn the ignition on to return the system to its previous settings. You can now make
adjustments normally, but you need to turn certain vehicle-dependent features back
on, such as:
• Heated seats.
• Cooled seats.
• Heated steering wheel.
• Heated mirrors.
• Heated rear window.
You can adjust the default remote start settings using the information display
controls. See Information Displays (page 89).
Automatic Settings
In hot weather, the system is set to 72°F (22°C). The cooled seats are set to high
(if available, and selected to AUTO in the information display).
In moderate weather, the system either heats or cools (based on previous
settings). The rear defroster, heated mirrors and heated seats do not
automatically turn on.
In cold weather, the system is set to 72°F (22°C). The heated seats are set to high
(if available, and selected to AUTO in the information display). The rear defroster
and heated mirrors automatically turn on.
Old Oct 25, 2017 | 06:36 AM
Deuce40s's Avatar
Deuce40s
Originally Posted by Just Strokin
Turn the ignition on to return the system to its previous settings. You can now make adjustments normally, but you need to turn certain vehicle-dependent features back on, such as:
This always make me shake my head. The most idiotic feature on the truck.
Old Oct 25, 2017 | 06:07 PM
Bugzilla46310
Stroking, thanks for the info. I actually read the manual but did not recall seeing that.
DerekF350disel
6.7L Power Stroke Diesel
26
Dec 18, 2017 05:34 AM
ruphianh
Nov 23, 2017 09:53 PM
Hotwhls
Dec 11, 2014 09:55 AM
DHPRO
Mar 17, 2014 07:21 AM
jd350b
Jan 17, 2014 10:27 AM
