E40d wont down shift to 1st
I have a 1993 F150 5.0 with a e4od transmission. 215000 miles.
when in OD the truck won't move after coming to a stop until about 2500 RPM. Does the same when I turn the OD switch off. If I manually shift to 1st or 2ND the truck accelerates normally. Additionally after driving the truck for more than 15 minutes then allowing it to sit for about 5 minutes the truck will properly accelerate from a stop while in OD.
I have changed the oil pan filter and checked fluid levels properly. I feel this is a electronic problem. I have heard to many stories of rebuilding a tranny just to have the same problem. Could this be a bad solenoid? Any advice would be appreciated.
How to Run a Self Test Paper clip method
If you plan to keep the truck and work on it yourself I highly suggest to invest in an Equus 3145 code reader. ~$25 USD at many retialers.
Using either method above run the Key On Engine Off (KOEO) tests and Stored Code (CM) display. List the three digit codes you may have gotten and when they were displayed. Keep in mind if all of the KOEO tests pass and/or no stored codes you will get the System Pass code 111 for each.
No codes means you did not initiate the self tests correctly or some other issue is preventing the computer from going into test mode.
If after all that fails, the Ford manual wants you to make sure the sensor is aligned correctly. Try going from 'Park' to '1' on the gearshift and make sure each selection feels right. If the shifter is sloppy/not lined up on the dash you may have a misaligned sensor.
Had same problem. I didn't get the solenoid plug completely snapped together. I had just repaired 6 exposed wires in plug. As soon as I got underneath and I felt click, all was good!
will not start with the key ??????? - 80-96 Ford Bronco Tech Support - Ford Bronco Zone Early Bronco Classic FullSize Broncos
I believe you are describing what Ford calls the Manual Lever Position/Transmission Range (MLPS/TR) Sensor
History;
As of 1994, the Neutral Safety Switch or Neutral Drive Switch (NDS) is referred to as a Manual Lever Position Sensor (MLPS) or Transmission Range (TR) Sensor (driver side of E4OD)
Adjustment Info
Source: by Richard C (Bigric, Money Pit)
"put it in neutral, loosen the bolts, and line up the marks."
Posted Image
MLPS shown is same for Bronco E4OD
Connector Pin-Out Diagram
Source: by Ryan M (FireGuy50) at http://oldfuelinject...ans_harness.gif The alternative is to back-
TR Signal (LB/Y) to Signal Return (Gy/R) resistance values:
P = 3770-4607 Ohms; R = 1304-1593 Ohms;
N = 660-807 Ohms; (D) = 361-442 Ohms;
2 = 190-232 Ohms;
1 = 78-95 Ohms.
or probe the MLP line with a volt meter while in Park, and set it to between 4.277 and 4.736 volts (ideally at 4.5065V, right in the middle of the two limits). As a "double-check" afterward, pull the lever down to 1st gear, and again test the MLP voltage; it should be between 0.293 and 1.167 volts, ideally in the middle at 0.73V. by SigEPblue
Posted Image
For anyone else with this same issue...
after retiving the the codes I received a 634 which is the MLPS or “neutral safety switch.” I replaced it after it tested bad. After replacing it, the truck would not start in park and drove in fail safe mode which is taking off in lower gear and hard shifts. I pulled the codes again and this time I got just about every transmission code listed. (Yes the notches on the mlps were lined up)
After tinkering for multiple weekends I was exhausted and just limped it into a shop. Luckily I found a honest shop and after 20 minutes they told me my PCM was fried. 315 dollars later my transmission is running like new.... for now.
Thanks for everyone’s help on here. Next time I’ll take the time to check the PCM myself.
