Need some help pls
Old Oct 23, 2017 | 06:48 PM
SC_Dave's Avatar
SC_Dave
Need some help pls
Clearing downed trees from a storm. Can’t get my truck out of 4wd I remember a thread on this but I can’t find it. I have limited internet and no power.
Old Oct 23, 2017 | 06:59 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Back and forth from reverse to drive on level ground and then into neutral usually works for me. You didn't mention hi or low 4wd so I assume hi, neutral is not needed from hi but it works for me when mine gets stuck.
Old Oct 23, 2017 | 07:34 PM
SC_Dave's Avatar
SC_Dave
It’s in low.
Old Oct 23, 2017 | 07:35 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by SC_Dave
It’s in low.
I'm not exactly sure how to do it, but if all else fails you can take the shift motor off the case and move the selector by hand.
Old Oct 23, 2017 | 07:48 PM
Walleye Hunter's Avatar
Walleye Hunter
In and out of low requires the transmission in neutral and foot on brakes. Sometimes mine takes close to 15 seconds to make the switch.
Old Oct 23, 2017 | 08:50 PM
jstihl's Avatar
jstihl
what he said works for me
Old Oct 24, 2017 | 09:46 AM
SC_Dave's Avatar
SC_Dave
Thanks very much guys. Got it out. I was in a bit of a bind. Lots of damage in my area from the storm but no one hurt. Still no power or internet.
SCD
Old Oct 24, 2017 | 10:03 AM
Sous's Avatar
Sous
FTE Emeritus
Dave, how did you get the truck out of 4 low? People in a similar situation might benefit from your advice in the future.
I saw the storms rolling through yesterday, luckily we were on the very southern part of it and only had heavy winds and rain.
Old Oct 24, 2017 | 10:12 AM
andym's Avatar
andym
We also caught some of it here, but it looked much worse up north. Glad everyone is OK!
Old Oct 24, 2017 | 10:42 AM
SC_Dave's Avatar
SC_Dave
Great point, sorry I forgot that.
I did as truckeemtnfords suggested and it worked. Went back and forth about 5 times.
SCD
Old Oct 24, 2017 | 10:43 AM
SC_Dave's Avatar
SC_Dave
Yep, more than 100 tress down in my community. Roofs off buildings and houses.
Old Oct 25, 2017 | 03:23 PM
hydro man 17's Avatar
hydro man 17
What Mark said is straight from the owners manual. I had the same issue the first time I tested to see if my 4WD even worked. Tried every which way to get out of 4 low to no avail. Then I read the directions and it worked first time!
Old Oct 25, 2017 | 03:36 PM
Walleye Hunter
What's funny is that this is how I found this site. I had to google my 4WD won't shift into low and it brought me here.
Old Oct 25, 2017 | 07:45 PM
andym's Avatar
andym
My story (now that we're sharing) is that I had a 1990 F-150 that I bought after a second major accident on my policy (thank you, ex-wife) in less than a year. The first problem I had was that it wouldn't run right on the rear tank. Did a google search, and many years later here I am still. The fact that Ford trucks are the best made trucks on the road today might have something to do with it, because that was my first of many Fords!
MikeRizz
Jan 23, 2012 04:23 PM
kdavis4x4
Dec 21, 2010 05:05 PM
Muktown
Mar 5, 2006 08:22 PM
Drgslayr
1983 - 2012 Ranger & B-Series
Nov 14, 2004 06:05 PM
1999XLT
Sep 15, 2002 07:21 PM
