T- Case will not go into low range
Old Mar 5, 2006 | 07:57 PM
Muktown's Avatar
Muktown
today when i was pulling people out of the ditch because of the snow we got i went into 4wd and it worked fine i was stopped so i switched it into 4 low and nothing. light did not come on in dash and it wasnt engaged. does anyone know why 4 high will work and not 4 low. i have esof
Old Mar 5, 2006 | 08:02 PM
JOE-M's Avatar
JOE-M
Did you have it in neutral with your foot on the brakes when you shifted it to 4wd low? These two things must be done to shift into or out of 4wd low.
Joe
Old Mar 5, 2006 | 08:08 PM
Muktown's Avatar
Muktown
thanks joe. i diddnt know it had to be in neutral i tried everything except that. park, rolling about 2 mph, stopped in drive, and nothing. so it wont work in park and has to be in neutral?
Old Mar 5, 2006 | 08:22 PM
JOE-M's Avatar
JOE-M
Yes, it has to be in drive or reverse for 4wd high and neutral with your foot on the brakes for 4wd low. Don't forget you have to do the same thing to get it out of 4wd low.
Joe
