I have a 96 F250 460 4x4 with an E4OD. Tranny was rebuilt about 10k miles ago. I'm having issues with the 2-3 shift. Everything was working great parked it to go into the store and came out and had no 2-3 shift. I can make it shift manually but not in Drive. I have checked the harness and it looks good. Also did a continuity check and it was good from the trans connection to the pcm. I checked the valve body and the 2-3 spring was sticking out. At that point I found a rebuilt valve body and stuck it in. Took it for a test drive and the same issue. Pulled the valve body back out and everything looked good and moved freely. Looking for any ideas. Thanks for the help.
The problem is new. It literally happened after I shut it down. Everything was working great after the rebuild.
Yes, the 96 flashes the of light when there's an issue. I was thinking it was some sort of electrical issue but the harness checks out good. I'm leaning towards an issue with the solenoid. I used a rebuilt one instead of new.
Technically it's not a manual shift but by going from 2 to D. That's the only way it will upshift into 3.
Finally had time to work on the tranny. I pulled the vb and inspected for broken springs and sticking valves and all looked good. Then pulled the accumulator and did the same. All was good. Replaced both gaskets and filled it with fluid. And sure enough the problem is still there.
I have found that it will shift into third when the rpms are around 3500 with the od light off. But if I turn the of light on it won't shift to third at any rpm.
Not sure if this is a solenoid or pcm issue. Any ideas?
My E4OD was shifting terrible. I had it rebuilt and it still was bad. I checked the PCM and had two capacitors hanging on by a thread. I went ahead and replaced the PCM and it shifts perfect now. I ran my code reader the other day and it showed a code that meant the trans was not in park. I replaced the MLPS and the code is gone and all is well. Personally I would check the PCM visually first. When I first ran codes before the rebuild it showed the solenoid was bad so it was replaced first but didn't fix it. Point is there is a code for the solenoid. Run the codes and see what you get. Sandy
Thanks Sandymane. I will take a look at the PCM when this weekend. I have check codes and there were none. I have checked the wiring from the PCM to the solenoid and all is good. Thanks for the help.
If it goes into 3rd sometimes, by manipulating the O/D cancel button, it's probably not a valvebody issue.
There are three sensors primarily used for shifting: TPS, VSS and MLPS. If any one of those are erratic or intermittent, you will have shifting problems. Does your speedometer bounce around, or is it smooth?
The speedo is smooth. The last time I checked the tps it was within the ranges. I will check the tps this weekend. Thanks for the tips.
The only way to get it to upshift to 3rd is to move the shifter from M2 to D. It shifts the same if the od light is on or off. It down shifts into all gears just fine.
