Water Pump
Old Oct 18, 2017 | 06:52 AM
boatn19's Avatar
boatn19
Water Pump
Hello All,
I’m relatively new to this forum, been lurking a while finally made an account.
Getting ready to replace my water pump again and want to make sure I get it right this time. It's leaking still so I'm guessing the bolts are not tight enough.
A few different YouTube videos references different torque lbs. one said 17 the other 50. Where can I get the shop manual for this application?
Would the coolant loss affect the interior heat?
Thanks in advance,
greg
2004 F250 XLT SD 6.0, 239k
Old Oct 18, 2017 | 07:37 AM
Carolina Rig's Avatar
Carolina Rig
17 lbf-ft on the M8 bolts for the water pump.
Why are you replacing it "again" and what part of the job are you concerned about getting right this time?
It's a straightforward job with the fan clutch being the biggest PIA.
Old Oct 18, 2017 | 08:10 AM
boatn19's Avatar
boatn19
I'll update my OP. It's leaking still so I'm guessing the bolts are not tight enough.
Old Oct 18, 2017 | 08:11 AM
boatn19's Avatar
boatn19
I appreciate the help, 17lb great thanks.
One last question, only the o-ring and no gasket or rtv, right?
Old Oct 18, 2017 | 11:48 AM
boatn19's Avatar
boatn19
I found the Ford install directions on the Ford website. Very cool.
01CoolantSystemDrain.pdf
03CoolingFanRnR.pdf
05CoolantPumpRnR.pdf
Old Oct 18, 2017 | 04:56 PM
Yahiko's Avatar
Yahiko
If you need more manual stuff just say so I can post PDFs for you.
The 2003 & 2004 years are a little harder to do so give me a few hrs
if you need anything.
Old Oct 18, 2017 | 05:21 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Correct.
If it's still leaking after you replaced the water pump, your concern is the seal.
I bought one from diesel site and almost a year after I had it, it started leaking. I called up Bob and he had me replace the seal with a Felpro. Hasn't leaked since.
Old Oct 18, 2017 | 10:05 PM
boatn19's Avatar
boatn19
Bad o-ring. Will replace with a felpro in the am if I can locate one. The three places were out today.
Old Oct 19, 2017 | 05:42 AM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
The waterpumps are a nightmare to change in these trucks. For that reason alone I put a BPD water pump in my truck when it was bullet proofed. I would recommend that to everyone because you most likely will send the truck to the bone yard with the same BPD pump still going. They last forever and is why they guarantee them for life.
Old Oct 20, 2017 | 09:07 AM
TooManyToys.'s Avatar
TooManyToys.
Pretty easy if you keep the stator off. Belt changes, pulleys .....
Old Oct 20, 2017 | 04:49 PM
DarkStarMedia's Avatar
DarkStarMedia
Really?!? I didn't mind much...but I had more access than most. it seems once you get the fan and shroud out it seems to go quickly.
Richard
Old Oct 21, 2017 | 06:36 PM
MisterCMK's Avatar
MisterCMK
This.
Everything is easier with the stator in the rafters where it belongs.
Old Oct 23, 2017 | 07:36 AM
boatn19's Avatar
boatn19
still leaking so I went to ford and they quoted me about 4k for the water pump and oil leak.
I will be getting smart on diesels quickly.
SO after my fun visit to ford I am not driving a truck that can barely get out of its own way. I feel like they did something but probably wont be able to prove it.
Also now getting two codes:
P0198 Oil Temp
P2262 Turbo Charger
The EOT and Water temp are the same 187-190.
Ford_Quote.pdf
Old Oct 23, 2017 | 07:41 AM
MisterCMK's Avatar
MisterCMK
Check the hose from the intake manifold to the MAP sensor. The MAP sensor is above the heater box. If that is disconnected it can cause the P2262 code.
Old Oct 23, 2017 | 07:48 AM
bismic's Avatar
bismic
P0198 indicates a short in the EOT sensor. You should check that out also.
