Water Pump
Old Oct 23, 2017 | 07:57 AM
boatn19's Avatar
boatn19
So I am loosing power now so will check the hose.
The coolant filter needs to open of closed? I can take a picture in a little bit.
Old Oct 23, 2017 | 06:55 PM
Yahiko's Avatar
Yahiko
Just in general I would check over all the connections anyway. Give them a little tug
so you know that they are clipped together.
Old Oct 24, 2017 | 06:26 PM
boatn19's Avatar
boatn19
When I got it back from Ford this know was closed, so I opened it. Not sure what the outcome should be.
Old Oct 24, 2017 | 06:29 PM
DarkStarMedia's Avatar
DarkStarMedia
I would change out the clamps to smooth type and get the right size... the worm clamps tend to damage the the rubber after repeated heat and pressure cycles.
(just a side observation)
Richard
Old Oct 24, 2017 | 06:34 PM
boatn19's Avatar
boatn19
Richard
Will do. NAPA have them?
Old Oct 24, 2017 | 07:06 PM
DarkStarMedia
dont know... probably... they are often called fuel injection hose clamps.
here is what they look like...
Amazon Amazon
there is also a worm style that is smooth inside but they are hard to find.
You can also use a spring clamp like the factory if the t-fitting is correct (not barbed).
Richard
EDT: you can also use this type with the proper tool... they look better but they are one use...
Amazon Amazon
Old Oct 29, 2017 | 10:31 AM
boatn19's Avatar
boatn19
Originally Posted by MisterCMK
Check the hose from the intake manifold to the MAP sensor. The MAP sensor is above the heater box. If that is disconnected it can cause the P2262 code.
Going to check this now. But would you explain “heater box”? Where is it?
Old Oct 29, 2017 | 10:38 AM
boatn19's Avatar
boatn19
https://www.amazon.com/HPS-FIC-14x10...ess+hose+clamp
Richard
https://www.amazon.com/Oetiker-Stepl...ess+hose+clamp
This is one job I am competent enough to handle hose clamps swapped out.
Old Oct 29, 2017 | 11:15 AM
lanneinbc's Avatar
lanneinbc
A question I can answer! I just did this the other day, see my thread My Two Trucks. Your MAP sensor is in the back right corner, near the hinge for the good on the passenger side. There's a hose from there to the exhaust manifold. Take the hose off at both ends and verify that it's clear, then remove the brass nipple from the manifold and clean it too. I used a toothpick. Then give some reps to Yahiko for me, for sharing the detailed instructions.
Old Oct 29, 2017 | 12:08 PM
boatn19's Avatar
boatn19
Wow thank you doing it now
Old Oct 29, 2017 | 12:57 PM
DarkStarMedia
the hose goes to the intake manifold, not the exhaust manifold.
and your heater box is the thing that your AC lines go to on the firewall, on the passenger side. (technically it's an evap box)
Richard
EDT:
Old Oct 30, 2017 | 07:42 AM
boatn19's Avatar
boatn19
Richard
EDT:
Thank you for your patience!
So from the back side of the MAP Sensor there is a 3/8" (estimate) hose a bit smaller than I interpreted. I followed it to the intake (about 12-14" long) cover and it was not connected. I suspect since the time of the check engine light and the two codes showing up. Which happens to be from the Ford Dealership so they must not have reconnected from their diagnostic visit.
I reconnected and the codes both cleared. I also reconnected and ensured the intake hose from the airfilter was good and connected along with the others that I had off from replacing the radiator (I Damaged when I was replacing the front cover gasket).
So now I am almost back to ground zero from before my two visits that caused me to chase my tail for the last week.
One last symptom is the truck is now idling rough. Once I figure this out then I'll get back to my original problem of an oil leak. But it was not idling rough before the trip to the shop.
Off to search the forum, Stay tuned.....
Old Nov 2, 2017 | 06:41 PM
  #28
boatn19's Avatar
boatn19
For the vibration at idle what should I be looking at on my scan guage?
Old Nov 3, 2017 | 05:29 AM
  #29
TooManyToys.'s Avatar
TooManyToys.
I’d be way more concerned about the puking from your degas bottle cap, aka in your terms, radiator cap. Which also may be why you’ve had water pump seal leaks.
Old Nov 3, 2017 | 06:49 AM
  #30
boatn19's Avatar
boatn19
i do not have a bad degas bottle cap aka in your terms a radiator cap.
I do do have a vibration at idle that is annoying.
