Winch install question
Old Oct 22, 2017 | 10:21 AM
HouseMouse's Avatar
HouseMouse
More..... Just found a YouBoob Video by Etrailer showing a SuperWinch being installed on a Auto Trailer using a Fuse relay block. Went to Etrailer and that Fuse block is not available there. Guessing at one point, it must have been a SuperWinch Part that came with the winch. Just follow the directions that comes with your winch for install.
Old Oct 22, 2017 | 12:34 PM
Whiplash2130's Avatar
Whiplash2130
Winch Wiring Let
After rereading everything, I now believe the solenoid mounted on the winch is enough to do the job. However, I will not install without a inline bar fuse. I bought a 250 amp fuse, but after re-reading the specs for the 15500# hoist max motor draw would be 440 amps. Sounds like a lot for the 4 ga. Wire.
Old Oct 22, 2017 | 01:08 PM
Biggsy90's Avatar
Biggsy90
So where and how are you going to attach the cables?
RGraff
Jul 31, 2013 11:46 AM
tyrantsparky
17
Jan 8, 2013 09:22 PM
BIGRED 7.3L
16
Oct 5, 2011 12:01 PM
Ryan50hrl
Electrical Systems/Wiring
Dec 17, 2008 09:58 PM
mybigredford
Oct 2, 2004 03:53 PM
