Battery Cable question
Old Dec 10, 2008 | 05:28 PM
Ryan50hrl's Avatar
Ryan50hrl
So here is my question....i'm looking to wire my winch in on my 07 truck...only catch is i DON'T want to cut my battery cable...and the stock battery only has one post.....Is anyone aware of a dual adaptor for the top post batteries?
I'd even be able to use an adapter that clamped on, had a post, and a stud w/wing nut.....any sort of adapter to allow to connections to one post...
Old Dec 10, 2008 | 05:43 PM
Franklin2's Avatar
Franklin2
Will something like this fit behind the nut that tightens the original battery clamp onto the battery? Or does yours not have a nut?
Old Dec 10, 2008 | 06:29 PM
Ryan50hrl's Avatar
Ryan50hrl
It would probably fit....but i'm leary to run that much amperage through that small of a contact patch....fitting there it probably won't sit flat against anything.....
Old Dec 10, 2008 | 07:24 PM
ReAX's Avatar
ReAX
I am going through a similar issue with winch connection. I had been using Optima blue tops which had the top post and a set of threaded post next to them. I am trying other batteries now and I don't have any room in my current terminals to add another pair of 6ga wires. I have two options, swap one of my fuse blocks for another with two outputs or go into the side terminals. I am shopping for side terminal bolts now, and this sounds like your best option, providing your battery has both styles.
Old Dec 10, 2008 | 08:59 PM
Franklin2's Avatar
Franklin2
I would take the clamp bolt you have now out, and find another that is longer. Put the new bolt back in with a nut and clamp the terminal back on the battery. Then you should have plenty of threads and the first nut to install the ring terminal on, and then squeeze it with a second nut with a locknut or star washer. Should have plenty of amp capacity.
Old Dec 10, 2008 | 10:04 PM
Ryan50hrl's Avatar
Ryan50hrl
I wonder if it is large enough.....the cabling i'm using is #2 welding cable which has a OD of .49.....those bolts can't be more than .25 diameter....Hum....
Old Dec 10, 2008 | 10:09 PM
ReAX's Avatar
ReAX
It's not just the bolt diameter. The surface on both sides of the connector are where the electrons pass. 1/0 wire can do very well with only a 3/8" bolt, so I suspect 1/4" would do for 2ga.
Old Dec 11, 2008 | 09:49 AM
Franklin2's Avatar
Franklin2
The ones I am familiar with are usually a 5/16 bolt. I am not familiar with all the newer trucks, but most have a short cable that also goes over to a starter relay. Do you have this setup, and do the studs on it have enough room to sneak another terminal underneath?
Old Dec 11, 2008 | 02:44 PM
Ryan50hrl's Avatar
Ryan50hrl
I don't think it does.....
Old Dec 17, 2008 | 09:58 PM
Ryan50hrl's Avatar
Ryan50hrl
It was way easier than i really expected....ford did a great job by putting a stud on the positive terminal, and a long bolt through the negative....
