Which battery...........
Old Aug 15, 2011 | 03:16 PM
coollooking96F350's Avatar
coollooking96F350
Actually turns over the engine? Or is it both?
Old Aug 15, 2011 | 03:25 PM
bad12jr's Avatar
bad12jr
Both. They are tied together on the passenger side.
Old Aug 15, 2011 | 03:26 PM
Copedawg's Avatar
Copedawg
both of them. the extra battery is for extra cranking/amps.
Old Aug 15, 2011 | 03:27 PM
coollooking96F350
Thanks guys. It is starting to act like I have a bad battery, now have to get them load tested to figure out which one it is..................
Old Aug 15, 2011 | 03:33 PM
bad12jr's Avatar
bad12jr
Make sure to unhook them otherwise you'll test both like I did the first time lol.
Old Aug 15, 2011 | 03:55 PM
Copedawg's Avatar
Copedawg
I would unhook both of the batteries then unhook them from each other....then test (voltage test with a mltimeter) in the am and see wich one is low. If you leave them both hooked to each other...the bad one may/will drain the good one.
Old Aug 15, 2011 | 05:31 PM
joe_13894's Avatar
joe_13894
One can start the truck just fine in the summer.
Come winter the truck doesn't want to start on one battery. How do I know? Last winter I had one of the ground wires to the block corrode and open up. The little body ground wire kept the left battery charged up but wouldn't help starting. Both batteries tested full and fine. As soon as I put a new ground wire on starting problems went away.
Old Aug 15, 2011 | 05:54 PM
fordpride's Avatar
fordpride
Its best to replace both at the sametime
Old Aug 15, 2011 | 08:36 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by fordpride
Its best to replace both at the sometime
Totally agree with that, but at the sAmetime.
Old Aug 15, 2011 | 09:30 PM
fordpride's Avatar
fordpride
I fixed it for you
It's this so called smart phone that keeps changing my words
Old Aug 16, 2011 | 08:11 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
I fixed it for you
Yea, I know what are you talking about, I dont like that.
Rockinfigs
All Things Towing
Jul 27, 2023 10:55 AM
HILLBILLY BOB
Oct 27, 2018 10:10 PM
john fin
Nov 24, 2011 06:11 PM
hojolabo
General Automotive Discussion
Oct 21, 2008 07:13 PM
