Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Shop lighting
Old Sep 20, 2003 | 03:39 AM
zanny's Avatar
zanny
Shop lighting
13hondacr250, the ballasts you have in there now, are rated for 50 degrees. Thats why your lights have trouble coming on and flickering, when it is cold. They make a zero degree ballast, which will cure that problem. The electronic ballast works a little better, but they are expensive.
zanny
Old Sep 20, 2003 | 04:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
Shop lighting
The electronic ballast 4' flourescents are dirt cheap at the home Box stores and they work well in the cold. I have had 3 of them for 2 years now and they worked on the coldest winter days in my attached but unheated drafty garage. They make a little noise on startup in the cold but perform well.
Old Sep 21, 2003 | 01:30 AM
zanny's Avatar
zanny
Shop lighting
There are a few type of electronic ballasts. The type the sell at home depot are not a true electronic ballast. That is why they make noise on real cold days. Those ballasts are for residential use. You can not use those type of ballasts in commercial or industrial applications. ( federally mandated energy conservation rules) A true electronic ballast have a removable cover, with a circiut board inside.
zanny
Old Sep 22, 2003 | 07:58 PM
cajunbull61's Avatar
cajunbull61
Shop lighting
In a recent issue of Family Handyman[I think] there was a article on shop lighting that talked about different ballasts for cold climates and such. It was a good article with useful info.
Old Sep 23, 2003 | 05:46 PM
mberet's Avatar
mberet
Shop lighting
I bought my shop lights at a school auction, I got old some Gym lights that are 220 cost me 175 duckies for 12 of them used 8 at first now only 6. Thought that TXU was going to love me but really our bill didnt go up that much. 8 was to much for 40 by 50 shop with 6 when the roll up door is up you can see my shop for miles at night. They are really nice cons bulbs cost 68 bucks and they take forever to come on and when they are coming on I can watch the meter outside go into Hyperdrive.
Old Sep 23, 2003 | 07:06 PM
dogman's Avatar
dogman
Shop lighting
(Quote) The question I have is I want to put a work bench in my shop and I want to be able to have a bright light overhead when I need it, but also want to be able to move it if it is going to get in the way. I was thinking of putting a flourescent light on some sort of a pulley or retractable cord.
I would mount the light on the wall infront of the work bench it will give you tons of lights and it's out of the way.
Old Sep 23, 2003 | 08:42 PM
mberet's Avatar
mberet
Shop lighting
Why couldnt you use something like track lighting, I dunno only problem I see making the 90 degree turn from overhead to wall. You can buy a shop light with a retractor cut the cord at the light and mount the light you want and use it or even a airhose reel with extension cords would work. The hard part is getting the light needed out of a bulb not 48 inches long without going to halogen but they suck to work under or around
Old Sep 24, 2003 | 12:27 AM
Torque1st's Avatar
Torque1st
Posting Legend
Shop lighting
If you put a light in front of you and are wearing safety glasses the glare off the glasses will be very bad. The light should be over your shoulders.
Old Sep 24, 2003 | 08:14 AM
Longneck's Avatar
Longneck
Shop lighting
Thanks for the tips. Seems like no matter the question, someone here has always done it twice (once the wrong way, once the right).
Longneck
Old Sep 24, 2003 | 04:01 PM
dogman's Avatar
dogman
Shop lighting
What I meant, is mount the light in front of you but put it above your head so you don't have the glare. Hey try this, get a buddy, power up the light and move it around and see were it works best for you. I just helped a friend with his a he did something neet his lights are on two slides so he can move it in and out from the wall as needed.
Longneck
Electrical Systems/Wiring
22
Oct 16, 2004 08:12 PM
Longneck
16
Apr 8, 2004 10:21 AM
Longneck
Oct 2, 2003 08:07 AM
Longneck
Sep 8, 2003 04:05 PM
Longneck
Oil & Lubrication
Aug 28, 2003 08:57 AM
