97 7.3 fuel problem!!!!
Hi, I have a 97 f250 7.3 and I was driving it the other day and my fuel filter light came on about a mile or two later it started running rough and then died I got out and check the filter and it looked good it's a brand new filter anyway.. I pressed the bleeder valve on the side of the filter housing and it just spit air out of it .. So I cranked it and pressed it again still air repeated this a couple times and finally it started and I got it back home .. now it has no problem starting right up idles great .. So I go to take it for a test drive and same thing fuel filter light comes on and eventually dies and have to bleed out the air till it starts back up now I noticed the faster I go the sooner it will happen .. I'm thinking I have a cracked fuel line but I can't find any leaks ... if anyone could give me some advice on where to start or what direction to go thAt would be great this is my first diesel .... thanks you
if less than a 1/4 tank, you could have a broken shower head
the fuel bowl has a little screen inside that could be clogged up too, its to put the air back to the tank. mine was so plugged up I had to remove it to clean it. most can use a q tip to gently remove the material. pull filter and its near the drivers side in the bowl
filadog23c
11-06-2019 10:45 AM
93IDITURBOPOWER
11-03-2016 10:54 PM
Orpackrat
07-10-2014 09:53 AM
tomherrick
18
05-27-2011 04:18 PM
