Help! Plz
Old Nov 16, 2017 | 09:07 PM
MontanaMama's Avatar
MontanaMama
Help! Plz
Ok so I have a 1997 ford f350 with the 7.3 international motor in it moved to Wyoming last December and husband didn't listen and did not put anti gel in the tank and it geled bad got it ungeled and it ran good for a sec and then it started acting liken it wasn't hitting all 8 and wouldn't go above 40mph and it's a standard transmission put new fuel in it and parked it and now it won't start we've replaced the fuel filter, we've done the position sensor in the front bumper we've pulled the chip we adjusted the idle we replaced the oil plug on the back side of engine and might I add that it's been yrs since he replaced the glow plugs and both batteries are dead but it wouldnt stay running even with charged batteries so I need some advise on what to do husband works the oil fields and I have no vehicle to drive while he's at work and I need one bad and yes I am mechanically inclined and the fuel pressure was checked and it is good
Old Nov 16, 2017 | 09:32 PM
z31freakify's Avatar
z31freakify
I would start by checking the fuel filter and see the condition. Make sure you fully charge the batteries or the truck will never start.
Oh! Welcome to FTE.
Old Nov 16, 2017 | 10:02 PM
oldbird1965's Avatar
oldbird1965
Fuel gel doesn't hurt anything, just have to get the truck in a warm place. Following this chart will help.
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Old Nov 17, 2017 | 06:30 AM
97-psd's Avatar
97-psd
Welcome to FTE!
Follow the chart, it will start!
I am curious as to how you adjusted the idle
Old Nov 17, 2017 | 11:18 AM
madpogue's Avatar
madpogue
I was about that too. Maybe a snow brush jammed between the skinny pedal and the seat?....
cabloom300
Jan 10, 2018 08:02 PM
DItR
Jun 20, 2012 10:09 PM
quality1construction
79
Mar 3, 2008 08:12 PM
myf350dually
Dec 14, 2007 10:01 PM
busakiller2001
Jan 30, 2006 06:06 AM
