Throttle Position Sensor
Old Oct 6, 2017 | 08:00 AM
80driver's Avatar
80driver
Trailering
I believe my throttle position sensor is going bad. Posted before about random shudder going down highway and checked codes and Throttle position shows out of range. I'm baffled because no auto parts locally stock TPS for 1986 Ranger 2.3 FI vehicles anymore. Nor do they carry knock sensors. Shows "obsolete item". What the heck! Can't get parts so is it time to send it to the scrap yard? Looked online at some of the offbrand parts suppliers and they ether don't carry the part or it's the wrong TPS. Any Ideas?
Old Oct 6, 2017 | 05:23 PM
shultzaberger's Avatar
shultzaberger
Does it look like this:
STANDARD MOTOR PRODUCTS TH12 Throttle Position Sensor (TPS) | RockAuto
Could you use one from a 2.0L from the same year?
Old Oct 6, 2017 | 06:33 PM
80driver's Avatar
80driver
Trailering
The 2.0 TPS looks just like the one on my truck with the 2.3. I guess I'll give it a try.
Old Oct 8, 2017 | 03:05 PM
dixie460's Avatar
dixie460
You can probably trash that knock sensor and not hurt a thing. If I remember right, knock sensors don't set fault codes.
Old Oct 9, 2017 | 03:04 PM
80driver's Avatar
80driver
Trailering
I believe the knock sensor controls the timing to control spark knock. Had a knock sensor go bad many years ago and the engine sounded like a bucket of bolts cause of the spark knock. Had to run premium gas or severely retard the timing to control it. Put in a new knock sensor and problem solved. Fast forward to now and have the same issues going on. Every where I look the sensor shows obsolete.
1986OhioF150
Jan 28, 2015 08:58 PM
rusted&busted
Sep 8, 2008 01:17 PM
Craig64
Jun 6, 2008 06:42 PM
matt3763
Jan 17, 2005 06:49 AM
bcj6402
Jun 28, 2002 01:32 PM
