Bad Throttle Position Sensor? ODB1 Codes
Old Jan 28, 2015 | 07:21 PM
1986OhioF150's Avatar
1986OhioF150
I pulled the OBD1 codes out of my 1986 F150 4x4 (302, AOD) and got these two codes:
23: (Trucks ONLY): Throttle Position (TP) sensor signal out of range
63: Throttle Position (TP) circuit fault, below minimum voltage
I am planning on replacing the throttle position sensor. Before I buy the part, is that most likely the cause or can something else trigger this fault? Also, will a Duralast one from Autozone work fine/are there any brands to avoid?
Thanks in advance!
Old Jan 28, 2015 | 08:58 PM
Franklin2's Avatar
Franklin2
A wiring problem to the TPS can cause one of those codes also. If you have a old time ohmmeter with the needle, you can use it to test the tps.
deeplist
Apr 29, 2015 02:01 PM
qixer01
Bronco II
13
Feb 26, 2010 01:47 AM
matt3763
Jan 17, 2005 06:49 AM
SuperB
Jun 14, 2004 12:36 PM
bcj6402
Jun 28, 2002 01:32 PM
