What rocker assy to use
T&D aluminum "street" set up is pricey but you won't find anyone with anything bad to say about it. They just don't fail in the formulation you're describing.
That said, from what I've read you'd be fine with factory styled non-adjustables as long as you add end stands. Spacer bushings would be nice too.
FWIW... for a cam/lifter/rocker assembly package I'd go to one of the top FE builders and have them put together a kit. I think long term satisfaction would be a lot better because they have the experience to spec a custom cam based on your displacement, heads, and power goals. They'll also select the right springs and assemble a durable rocker setup.
on
First roller rocker's I remember for a FE was in the late 80's maybe early 90's and some considered them not as strong as stock rockers, hardly ever see a rocker break, most times it's the shaft, end stands helped with that issue.
Pretty much during all of the FE's glory days, Drags, NASCAR, LeMons all done on stock type iron rockers.
Unless you plan on big lifts or heavy spring pressures about any quality rocker system will work as long as it has end stands.
I liked the unified stand of the Erson's plus I got a good deal on a set, other wise I'd probably have a set of stockers with end stands.
nkf
12-27-2016 12:38 PM
93f250xl
11-29-2013 04:39 PM
1bad67sbf
04-15-2010 10:08 PM
SIXD9R
53
12-08-2009 04:33 PM
bigblockhead
03-18-2000 08:56 PM
