i want some advice on rocker arms. i need to know alum or ss. i have some comp cams mag roller tip rockers (new) and i just got some edelbrock heads and am thinking about full rollers. my ? is should i get alum or stainless steel roller rockers. what are good and low $, after buying the heads the motor fund is very low im thinking under $150. or should i use what i have, this will be driven alot!
the heads are good for bottom end and the cam is mid to high. i was wondering if they will help each other or fight each other (heads 0-5500 cam 2500-6000
