Here's my problem. Window got stuck half way down. I took interior door panel off and moisture barrier. I can see motor running and regulator arm with teeth moving but nothing else is moving. What did i break if the teeth are going both directions but nothing is moving up and down? I manually lifted window up to seal the interior from rain, i can move window up and down by moving channel manually.
I know nothing about window motors, so I’ll chime in...does the motor have a “full down” position that it needs to be in when you install it (and the window was actually fully down)? If so, maybe the motor was in the halfway up position when you installed it. Just throwing that out there in case it’s a possibility.
Ok, figured it out, auto parts store sold me passenger side for drivers side, wasn't marked on box but i goggled it, got the right one , works properly. Thanks
