Transmission pan leak
Old Sep 30, 2017 | 08:26 AM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
I had my transmission rebuilt last year. Since then I had to take it back to have leaks repaired around the pan. The installer replaced two cork gaskets and finally used a rubber gasket with crush washers. However I still have leaks. My warranty is about to expire and I'd like to not have to keep going back. Any idea on what I can do?
Old Sep 30, 2017 | 08:30 AM
oldbird1965's Avatar
oldbird1965
I had the same situation. I tried several different pan gaskets then was told the original gasket was reuseable. I haven't had a leak since.
Old Sep 30, 2017 | 08:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Quite often when cork gaskets are used the pan gets deformed around the bolt holes. If that happens that pan will always leak.
Old Sep 30, 2017 | 08:56 AM
'74 Ford 250 CS
Thanks guys. So, a new pan I suppose. Any recommendations?
One more thing. Last weekend I used degreaser to see where the leaks were coming from. The seepage is slow but slowly making the pan look wet. I've notice behind the trans the drive shaft comes out of the trans, looks like it has slung some type of oil onto the bottom of the truck. I degreased that as well but it seems to be coming back. I now notice a red tint to it , like trans fluid, but can see major leakage to cause the bottom of the truck to look wet. Any ideas?
Old Sep 30, 2017 | 02:55 PM
Mark Kovalsky
I recommend a stock 4R100 pan. Many of them have drain plugs.
Old Oct 22, 2017 | 07:36 AM
'74 Ford 250 CS
Got the truck back from the shop. Either he misspoke the last time or his guy didn’t do the what he wanted, but I didn’t have the reusable gasket or rubber with steel washers in the bolt holes. I assume the one after the cork gasket was a fel pro gasket. So, we shall see if there are any leaks going forward. Still have to get the yoke plate sealed up.
Sullid01
Mar 17, 2022 08:21 AM
blacklab1
Aug 3, 2018 07:32 AM
minnesotafisherman
Sep 22, 2012 11:44 PM
RustyBeach77
1997 - 2003 F150
Jul 19, 2012 01:16 PM
maples01
Apr 14, 2005 04:26 PM
