Overdrive Off light blinking
Old Sep 19, 2017 | 10:45 PM
Douglas S. Bevan's Avatar
Douglas S. Bevan
So, sometimes, the Overdrive Off light starts blinking, but, doesn't always stay blinking. Sometimes it stops, within a few miles. Ant thoughts, as to what might be going on ?
Old Sep 20, 2017 | 07:30 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, I know what's going on. Something is wrong with the transmission system. To find out what's wrong you need to get the codes read. The places that read codes free usually cannot read these codes. You need either a good independent shop or a Ford dealer.
Old Sep 20, 2017 | 07:48 AM
subford's Avatar
subford
Or you can buy a code reader and read them yourself.
Here is one that most auto part stores sell or amazon:
At amazon:
Amazon Amazon
Old Sep 21, 2017 | 09:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
If your confused Doug,they're both right.
Mark is thinking if you own a truck with a powerstroke diesel engine and subford is thinking if you own a older (pre-obd2) IDI diesel or gas engine.
Old Sep 21, 2017 | 11:37 PM
cbakker's Avatar
cbakker
You've heard from the experts here already, but is it possible it's just a bad toggle switch in the shifter? Between mark and subford they will have the answer. Rule/step number 1 is to check the codes like they said.
Old Sep 22, 2017 | 06:21 AM
subford's Avatar
subford
He has a 1995 F150.
He has an OBD1 Truck.
So he more than likely has a 4R70W transmission.
Old Sep 22, 2017 | 09:26 AM
Mark Kovalsky
No, it isn't possible. A bad switch on the shifter will not make the OD OFF light flash.
Old Sep 22, 2017 | 10:02 AM
1996_5.8's Avatar
1996_5.8
Check your fuses
Old Sep 22, 2017 | 11:06 AM
cbakker's Avatar
cbakker
Thanks. I assumed if it was it would be throwing the OD in and out as well.
scav_one19
Jun 26, 2013 08:15 PM
turbo930ss
13
May 17, 2013 12:36 PM
bjis
Apr 5, 2010 10:09 PM
madjak
21
Feb 16, 2009 02:32 PM
live2hunt
Mar 7, 2006 08:37 AM
