Sponsored by: Real Truck
Brake light
Old Sep 19, 2017 | 02:23 PM
MTP55's Avatar
MTP55
Brake light
2000 F-250 with 7.3 PSD. Brake light came on dash and dings while cruising at 55 down a paved road. The brakes work fine. There is the normal amount t of fluid in tank. What could cause this?
Old Sep 19, 2017 | 03:33 PM
projectSHO89's Avatar
projectSHO89
Check the parking brake lever adjustment, make sure it fully releases.
Old Sep 19, 2017 | 03:36 PM
MTP55's Avatar
MTP55
As in gear shift park or the one under dash? We don't use the one under the dash. Auto trans.
Old Sep 19, 2017 | 03:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
Brake System Warning
Momentarily illuminates when the ignition is turned to the ON position. Also illuminates if the parking brake is engaged. Illumination after parking brake is released indicates low brake fluid level and the brake system should be inspected immediately.
Old Sep 19, 2017 | 11:30 PM
MTP55's Avatar
MTP55
Sounds strangely like the owners manual. There is all the fluid in the reservoir and it dings constantly. The manual says nothing about that. Could a wire somewhere be causing an issue.
Old Sep 20, 2017 | 07:55 AM
DogRidesInBack's Avatar
DogRidesInBack
Are you sure? Maybe it got used once by accident and not released?
Old Sep 20, 2017 | 07:59 AM
MTP55's Avatar
MTP55
I can check today. This one is my bosses truck. It's odd because it came on and started singing just going down the road.
Old Sep 20, 2017 | 10:12 AM
Mike1's Avatar
Mike1
Sometimes the E-Brake gets loose, pull on the release lever and at the same time pull on the E-Brake in an upward motion towards the Dash then let go of the release handle, see if light goes off. If the E-Brake isn't used on a normal basis, I wouldn't press it down to apply it, it may hang up or your cable could snap. My 95 F250 the pedal was loose and used to fall about 1/2 inch and bring the light on. My 03 F350 had bailing wire wrapped around it to hold it up when I bought the truck, I guess the PO figured that was the way to fix it...LOL
Old Sep 20, 2017 | 10:27 AM
MTP55's Avatar
MTP55
That May have fixed it. I heard something move into place. We will see if it comes back on. Thanks
Chris Thiessen
Jun 15, 2019 09:44 AM
lalberts
Nov 30, 2016 01:49 PM
h20thief
Oct 23, 2012 10:41 AM
littleme13
Jul 27, 2006 01:24 AM
Al Barrs
Oct 12, 2004 12:43 PM
