Parking Brake
Old Oct 18, 2016 | 09:57 PM
lalberts's Avatar
lalberts
Parking Brake
Did the park brake on a 1973 F-250 have an indicator warning light that came on when the Park brake was applied? If so where was the switch located? I have a Manual Transmission and I do Use the park brake often and want to eliminate drive-in off with the park brake on.
Old Oct 18, 2016 | 10:11 PM
DieselCamper's Avatar
DieselCamper
I know my 77 doesn't. It does have a red brake light on the dash that comes on when it senses that the brake pressures aren't at the correct ratio, which means you have a brake issue. I don't know about a 73 tho.
Old Oct 18, 2016 | 10:32 PM
lalberts's Avatar
lalberts
Mine does have the Red Brake light in Dash and it is fully functional but is not wired to park brake pedal. I bet it can be modified to work that way!
Old Oct 18, 2016 | 10:50 PM
DieselCamper
Oh! I see what you're saying. Anything can be done with enough time and ingenuity!
Old Oct 18, 2016 | 11:06 PM
PapaBearYuma's Avatar
PapaBearYuma
Our trucks didn't come with that type of warning lamp, but I'm sure you could rig something up. Maybe a brake pedal switch under the parking brake?
Old Oct 20, 2016 | 01:18 PM
redmt79's Avatar
redmt79
This may be of help to you. I have not had a chance to do it to my EB or either of my 79's but intend to.
Brake Warning light / emergency brake warning light - ClassicBroncos.com Forums
Old Oct 23, 2016 | 11:16 PM
lalberts's Avatar
lalberts
Ordered mine today, will let ya know when I get it and how well it works
Old Oct 24, 2016 | 07:19 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on NO 73-79 trucks did not come with a indicator light when the park brake is on. That is a new vehicle ism...I would try the link/product that redmt79 sent you. FYI it is for 66-77 smaller Bronco's though, not full size 78/79 Bronco's.
And do NOT mess with that red "Brake" warning light set up on your dash. That light is wired to your brake proportional valve and is suppose to light up when you 1st start the truck to do a circuit test, and then go out.
If should only come any other time if you have a major failure of you brake system. Like a blown line/lean in the sealed system and the floating piston inside moves to trip the light.
A actual brake pedal switch modded to work on the park brake would be a route to try, just wire it to a separate added on light.
Old Nov 22, 2016 | 09:54 PM
lalberts's Avatar
lalberts
Got the switch You mentioned earlier installed it and it worked first Time with NO problem! Thank You for the advice!
Old Nov 30, 2016 | 01:49 PM
redmt79's Avatar
redmt79
Glad to hear it! Some day I will get around to doing it too.
storage_man
2015 - 2020 F150
23
Oct 23, 2019 12:47 PM
Chris Thiessen
Jun 15, 2019 09:44 AM
silar
Sep 22, 2014 09:59 PM
LFDavidson
Jan 28, 2014 05:54 PM
Al Barrs
Oct 12, 2004 12:43 PM
