C-4 No Reverse
Old Sep 15, 2017 | 09:37 PM
Dads79's Avatar
Dads79
C-4 No Reverse
Hello all. I have 78 F-100 Barn find I'm trying to put back on the road. It has sat forever. It has 302 V-8 and C-4 transmission. I got it running and went though brake system. The transmission had almost no fluid in it ,and was leaking at around pan. I pulled the pan last Sunday,drained about a quart of fluid. I changed the filter and refilled the fluid Type F . I was able to drive it around the yard and it shifted up though the gears. But I have nothing in Reverse. I'm not a master mechanic,and have never opened a tranny until now. Could it just be as simple as an adjustment to a band ? Any ideas would be helpful. Hopefully the transmission wont have to be rebuild . Thanks for time
Old Sep 16, 2017 | 12:23 AM
olblue77's Avatar
olblue77
To be honest, You should probably take it to a shop and have them diagnose the issue. I'll tell you from my experience (I've pretty much blown up my C4 3 times so I've learned a little from the shop I take it to) It's probably the reverse clutch band. My main drive band went out last time I had problems with it. I am not positive but I'm not sure if you can just buy a single clutch band but I could be wrong (there's a reason I stay away from transmissions) if you're set on doing it yourself, study up. Youtube, ask people in the transmission section of this forum. It's under Mis. and then you will see the transmission section. Make sure you know what you're doing or else you could set yourself up for a nice shop bill to actually fix what you tried to and what you accidentally also messed up trying to fix the original issue.
P.S. automatic transmissions suck. Hope I helped,
-Caleb
Old Sep 16, 2017 | 08:04 AM
dlburch's Avatar
dlburch
not sure how deep you want to get into it, but I've attached the troubleshooting section of an old transmission manual I have...the manual includes c4 (and c6) rebuild procedures, but it is too large to attach here...
File Type: pdf
Old Sep 17, 2017 | 05:32 PM
offroadbronco's Avatar
offroadbronco
I had the reverse/low band break in my c4 but I couldn't go forward or reverse in that situation. I have found that reverse is the first to go when the fluid is low. Double check fluid level.
You can also try and adjust the tension to see if that may help.
The c4 is pretty stuid simple to rebuild (as transmissions go).
You can just buy the bands, but you will have to disassemble the trans to get that far so being you don't know the condition, I'd rebuild it. Buy the book and read through it a couple of times.
KAT_Ayanami
Mar 8, 2022 06:04 PM
Justin's Green Truck
1997 - 2003 F150
Nov 28, 2010 07:27 AM
Zookie400
Jun 30, 2009 11:03 PM
burninfordrubber
Apr 10, 2008 05:07 PM
mebe2k
Dec 24, 2003 02:59 AM
