Help! C6 has no reverse
Old Dec 23, 2003 | 02:50 AM
mebe2k's Avatar
mebe2k
I have a 74 F600 with a 460 and C6 trans in it. The transmission will not go into reverse. it acts like its in neutral. When I shift into 1, 2, or Drive it engages just fine. I've checked the fluid level with the trans hot and the truck idling, and the fluid level is fine. I've also checked the shifter adjustment and it is also correct. Is there anything else I can check, or is my transmission shot? Thanks.
Old Dec 23, 2003 | 04:07 PM
ron78supercab's Avatar
ron78supercab
Could be your reverse clutch that went bad.
Old Dec 23, 2003 | 06:31 PM
DeFrote's Avatar
DeFrote
Question
I have a Ford Van and it is doing the same thing yours is doing. What have you done to fix it and did it work?
Old Dec 24, 2003 | 02:59 AM
mebe2k's Avatar
mebe2k
I also suspect the reverse clutch... I was hoping it would be something stupid like the fluid strainer.. The strange thing is, it happened all of a sudden.. Well.. actually it always had a 1-2 second pause before reverse would catch.. but once it caught it never slipped or anything.. any other suggestions?
latechbanjo
18
Aug 16, 2016 08:29 PM
mschrein
Aug 14, 2016 08:51 PM
Fordman96
May 24, 2016 09:25 PM
Jared Harrington
Aug 6, 2015 03:33 PM
catbird7
Jan 28, 2013 03:48 PM
