Bolt help
Old Sep 15, 2017 | 02:28 PM
Iaff113's Avatar
Iaff113
Bolt help
Anyone have a special trick to get the nut off the stud that holds the oil dip stick tube on. It's rounded off and I can't get anything on it.
Old Sep 15, 2017 | 04:39 PM
Yahiko's Avatar
Yahiko
6point socket and if that won't do it you will have to go to the bolt remover tools.
Old Sep 15, 2017 | 04:57 PM
Iaff113's Avatar
Iaff113
Yeah tried every type of socket tried to get vise grips on it with no luck. Their is just no room around that nut. I looked at trying a deep well bolt remover but it didn't look like I would have enough room to put it on and try to turn it.
Old Sep 15, 2017 | 06:34 PM
Yahiko's Avatar
Yahiko
You may be stuck cutting the stud and then using the remover.
Then it will be a case of finding a new stud.
Have you heated the nut to break free any thing holding it?
Old Sep 16, 2017 | 07:07 AM
Iaff113's Avatar
Iaff113
Yeah that's what I'm gona do when I have some more time . Does ford sell these as single bolts or do you have to buy a kit.
Old Sep 16, 2017 | 04:58 PM
Yahiko's Avatar
Yahiko
I would look on Ebay first for singles.
Alsi I have a guy bit will have to get his
contact info and send it to you. He is
well worth talking to.
Old Sep 16, 2017 | 05:16 PM
Iaff113's Avatar
Iaff113
The ford dealer right down from my house actually had them in singles and had the one I needed
Old Sep 16, 2017 | 06:09 PM
Yahiko's Avatar
Yahiko
Nice. How much did you have to pay for the beasty?
Also can you post the part number just in case
else someone needs one.
Old Sep 17, 2017 | 01:04 AM
Apocalypse's Avatar
Apocalypse
I would get that deep well on it and use vice grips on the socket.
Old Sep 22, 2017 | 07:08 AM
Iaff113's Avatar
Iaff113
The bolt with the stud was $5 at my local dealer. They just gave me a loose part not in a bag so Im not sure what the number is, I know when I looked a WBL ford parts I could not find it. I ended up getting the bolt backed off far enough with an extractor and then cutting the stud off between the nut and the valve cover bolt. After that the only pain is the two rear lower blots, the 12MM ratchet wrench made life easier for them.
Steven Stocki
Oct 25, 2016 09:36 PM
FordBoy2012
1997 - 2003 F150
Apr 14, 2013 07:07 PM
DBGrif91
Jun 10, 2012 11:49 AM
93Ranger
1983 - 2012 Ranger & B-Series
Sep 28, 2011 01:26 PM
