Yes but, the -10 part refers to 10 threads per inch. Are you sure that's what the bolt threads are?
Also "rethreading" a nut to a different thread pitch isn't recommended, material was removed when the original threads were cut and even more will be removed when you make the second cut, leaving you with a seriously compromised fastener. Also (I have done this before) as the tap cuts the new threads, the chips it makes as it crosses the old threads will be oddly shaped an get in the cutting edges of the tap causing it to "gall", the second threads you cut will be smeared and rough with sections missing where the old and new threads cross. As TooManyToys was alluding too above, a 3/4 inch bolt is probably holding something pretty important together, be certain this bolt is just for looks and has very little pressure on it as it will not be anywhere near as strong as a proper 3/4 bolt and nut.
First, if it's the bolt that was factory installed, then it's metric. Nothing assembled on vehicles for a very long time has been imperial. Trying to thread the nut imperial ain't going to help fitment to the factory bolt.
Are both the bolt and nut the exact same parts that came off the vehicle? How about removing both a seeing if it's been cross threaded.
Put the socket on the nut (not the bolt head) put a piece of pipe (24in should be enough but longer is ok) over the breaker bar, stand on the pipe and bounce a little. 1/2 drive or bigger and six point socket recommended. That thing is tight! The bolt and nut should be ok.
Sorry Jack, my memory is slipping. i have 4 vehicles I'm working on right now and the numbers are flying around in my head. He still needs a BFB...............LOL
When in doubt , punt , take a close look at the threads if smoothed out then there's your issue , sometimes if not too flattened you can run a file into the deep thread to help the nut add a little WD for lube, you can always pull one off a wreak in the junk yard worse case, 100 bucks from the dealer is paying for somebody new phone
Genuine Ford OEM Track Bar Bolt Kit LB 1999-2004 Ford Super Duty F250 and F350 4x4 Trucks
The Track Bar Bolt Kit includes bolt and nut for factory installed track bar mounting.
Qty. 1 - Part# W706345-S439 -M20 Shoulder Bolt
Qty. 1 - Part# N811886-S436 -M20x2.5 Flange Nut
Forget about buying a tap. If you have to run a tap through ANY suspension nut (or die on a suspension bolt) You should just replace them. You just don't have to go to FOMOCO for it. There's plenty of after market sources for Grade-8 nuts and bolts specifically made for suspension.
