Sponsored by: Real Truck
Stalls when put in reverse
Old Sep 14, 2017 | 10:50 AM
Loftatsea's Avatar
Loftatsea
I have a 2003 F250 with a 5.4. Whenever I put it in reverse and hit the gas it stalls out. If I baby the pedal it doesn't stall. Now it is starting to stall when I come to a stop as well. Starts right back up each time. I was told it was most likely the lock up solenoid in the tranny. Interested in what others think. And if it is the lock up solenoid how difficult is it to replace? Thanks.
Old Sep 14, 2017 | 11:53 AM
DogRidesInBack's Avatar
DogRidesInBack
Vacuum leaks? Might have nothing to do with the transmission.
Old Sep 14, 2017 | 11:58 AM
Mike1's Avatar
Mike1
Put a code reader on it and see if you have any codes, This sounds more like a vacuum leak to me that it does any lockup solenoid.
Old Sep 14, 2017 | 10:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low transmission fluid can do this, too.
Old Sep 15, 2017 | 10:49 PM
fordmerc's Avatar
fordmerc
I agree. Check your trans fluid.
Vodnik
Sep 11, 2016 10:39 PM
Andrew121
2004 - 2008 F150
Mar 21, 2016 08:11 AM
wmiller
21
Dec 11, 2008 05:48 AM
muckypaws
1978 - 1996 Big Bronco
Dec 28, 2005 06:02 AM
calhuntsman
Apr 4, 2002 02:29 PM
