Sponsored by: Real Truck
Gauge Cluster LEDs
Old Sep 15, 2017 | 02:44 AM
stowbilly96's Avatar
stowbilly96
Gauge Cluster LEDs
I'm changing up the gauge cluster. I've already changed the color form green to blue, and now I'm soldering in individual LEDs in place of the twist lock style 194 bulbs.
Ive completed the tach lights, with three series of three 3mm LEDs secured inside the white gauge cluster housing. Unfortunatelt they don't proved as much light as I'd hoped, even though it is even with no hotspots.
Tomorrow I'm going to finish out the rest of the gauge cluster with the white 3mm. I'm also thinking about doing a second set of LEDs mounted to the rear of the actual gauge faces. These ones I'm going to make blue to exaggerate the blue film I used to replace the factory green. The white to blue ratio SHOULD allow me to keep the odometer a cool white, while making the blue richer. The blue also makes the orange needles very vibrant, like putting neon under a black light. This is what the gauges looked like as of this morning. I'll update with more pictures tomorrow night when it's (hopefully) finished.
Old Sep 15, 2017 | 06:39 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Man.... I been wanting to do something ti mine forever.... almost can't see anything at night anymore
Old Sep 15, 2017 | 05:33 PM
jp267's Avatar
jp267
Same here. 50% of the bulbs are burned out and the ones that still work are so dim they're almost worthless. I had to get some small stick on LED lights that plug into the 12v power outlet to see.
Old Sep 16, 2017 | 01:42 AM
stowbilly96
So things didn't pan out quite they way I'd hoped. The led strips I had mounted inside the cluster fell and were bouncing around inside the cluster. I previously had duct tape (the reflective kind actually used for ducts) inside the gauges to eliminate hot spots, but removed it so as to not conduct through it when I soldered in the LEDs. Unfortunately, the LEDs I was going to mount inside didn't work out due to clearance issues with the gauges, so I'm back to square one. I did solder in two rows of 3 LEDs and plug them in where the smaller bulb at the top dead center was before (168 maybe? It's a T5 base, I know that). So now I'm on the hunt for some good LEDs that are designed and emit light in a similar fashion to the 194 incandescent bulbs that came with the truck.
i put dielectric grease on all the LED bulbs I had in before and that appears to have solved the flashing/flickering, which I believe was caused by bad conductivity.
Old Sep 16, 2017 | 01:49 AM
jp267's Avatar
jp267
Too bad. That stinks. Did your truck use 194 or or size 74 twist locks? Mine is the tiny 74. I ordered some leds from China a few months ago. Decided to try one today. Once I reversed the bulb so the polarity was correct the pc74 bulb worked. Very bright.
FordTruckfan89
Mar 27, 2018 08:42 PM
josh99ta
2004 - 2008 F150
Apr 25, 2017 04:56 PM
DirtStripHero
1997 - 2003 F150
Sep 12, 2009 02:11 PM
GeneStoner
15
May 16, 2004 08:05 PM
TheMachfather
Jan 19, 2004 01:57 PM
