1978 - 1996 Big Bronco
Stalling when in reverse
Old Dec 28, 2005 | 02:29 AM
muckypaws's Avatar
muckypaws
Morning all,
Hope you all had a good Christmas!
Am back at work today and I've noticed my truck has developed an annoying habit of stalling when I put it in reverse. Its happened quite a few times now when I get to work and go to park it up. I don't get any codes and it can't be temperature/ run time related as its after a 30 mile journey. When I come to a stop I can put it in reverse, the vehicle will move back about a quarter of a wheel turn and then dies. It restarts without hesitation and continues to drive ok after that.
I don't recall whether I have my foot on the gas or not - probably not as its only just gone into gear. Its on a flat hard surface so its not gradient related.
Recently had a tune up etc and runs perfect all other times.
Any ideas? Is reverse a higher ratio than 1st perhapse?
Simon,
Old Dec 28, 2005 | 02:54 AM
ford390gashog's Avatar
ford390gashog
low idle, bad t/c or a vacuum leak.
Old Dec 28, 2005 | 05:36 AM
muckypaws's Avatar
muckypaws
idle is around 600-800, has had new torque convertor a month or so ago, might be vacuum leak but have check and replaced most of the hoses recently...
Old Dec 28, 2005 | 05:37 AM
ford390gashog
is that idle in drive?
Old Dec 28, 2005 | 05:56 AM
muckypaws's Avatar
muckypaws
its nearer the 800+ rpm mark when idle in drive.
Old Dec 28, 2005 | 06:02 AM
muckypaws's Avatar
muckypaws
you might be on the right lines mentioning the idle actually. I've also noticed it is not idleing as fast on start up as before. Used to be around 1200-1400rpm but is now nearer 1000rpm. I'll have a look at the IAC - probably due for a clean.
Encho
17
Feb 8, 2018 02:14 PM
Simon78
6.4L Power Stroke Diesel
Feb 29, 2016 05:47 PM
Skydivelout
Sep 17, 2015 07:33 AM
Kouwenberg7.3
Apr 26, 2014 06:04 PM
wallsy
Australia Chapter
50
Feb 2, 2014 01:33 AM
