Need help with trailer lights
Old Sep 13, 2017 | 06:36 PM
johnsonjf's Avatar
johnsonjf
i have an 04 Excursion, Limites, 4x4, 6.0PSD. My trailer lights are not working. I have checked every fuse under the dash, I have taken out the relays under the hood, tapped them, cleaned them and still nothing. There are no blown fuses anywhere, the electric brake controller still has power, the plug is not getting any power on any circuit. Any suggestions?
Old Sep 13, 2017 | 06:51 PM
Slamdunkpro's Avatar
Slamdunkpro
No power at the 7 pin plug? How about the 4 pin ? Are you checking at the plug with a voltmeter or thru the trailer connector?
Old Sep 13, 2017 | 09:37 PM
johnsonjf's Avatar
johnsonjf
Finally discovered the issue. It was in the body shop back in May, they had to remove the bumper as part of the repair and truck failed to reconnect the trailer pigtail to the main harness. Once I discovered that it was easy.
Thanks
Gwilkrrs
6.4L Power Stroke Diesel
Apr 30, 2015 05:29 PM
akpolaris
Nov 6, 2010 05:05 PM
s2gots
Nov 29, 2007 11:12 PM
buttz
May 17, 2007 05:44 PM
92GT5ohRed
Electrical Systems/Wiring
May 7, 2005 05:03 PM
