Caster Sleeve: Causing upper ball joint bind
Old Sep 13, 2017 | 06:02 AM
fatboyjoe500's Avatar
fatboyjoe500
Hi, new to the forum. Checked tech folders but could not find info. Is there a special procedure in installing caster sleeves? I tried changing to new sleeves but when I tried to install them, they were tight. I bought exact same ones from Oreillys. I tried hammering them in but no luck. Any input will be greatly appreciated. Thank you.
Old Sep 13, 2017 | 08:22 AM
rock2610d's Avatar
rock2610d
When I did mine I reused the oem ones.
I used a wire brush and sand paper on both the sleeve and mating surfaces until they would go in correctly.
I lubed the outside of sleeve with antiseize too. NOT the ball joint hole though.
I suspect the mating hole needs preped. It needs to be seated correctly before the ball joint is put in and tightened down.
Old Sep 13, 2017 | 09:12 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Clean clean and clean. The bore in the yoke will need to completely clean and and free of corrosion.
Emery cloth is helpful.
Old Sep 13, 2017 | 03:17 PM
fatboyjoe500
Thank you very much for the help! I will work on it this weekend. Thanks again.
Old Sep 13, 2017 | 09:48 PM
Restlesswildman's Avatar
Restlesswildman
are you installing them in the same position as the original?
the hole is off center in the bushing.
use a paper flapper wheel and clean bushing hole out.
apply a light coat of grease on bushing.
you may have to open the split in the bushing hole. it collapses bit when pinch bolt is torqued.
mgmoore7
Sep 18, 2016 09:00 PM
Duke78
Jan 14, 2009 05:11 AM
Mityford
May 20, 2004 04:04 PM
Greg Gilmore
Feb 27, 2004 05:59 PM
somelus
Oct 16, 2003 04:43 PM
