Sponsored by: Real Truck
Pitch Sensor?
Old Sep 12, 2017 | 08:52 AM
thomabb's Avatar
thomabb
Pitch Sensor?
I asked this over on the 6.2 forum without much luck, so I will try here. Truck is 2012 F250XL single cab 6.2. Where is the pitch sensor on this truck? There are times the hill start assist will keep the brakes applied on level ground, and occasionally I will crest a hill onto a level stretch and the truck doesn't want to upshift. So I am thinking the pitch (incline) sensor needs recalibrated. Anyone know where it is?
Old Sep 12, 2017 | 09:48 AM
Just Strokin's Avatar
Just Strokin
might be part of the instrument panel cluster (IPC). I would see about contacting CircuitBoardMedics on this site. Or see if you can find their website or phone number. They can probably answer your questions.
Old Sep 12, 2017 | 10:00 PM
projectnitemare's Avatar
projectnitemare
Not 100% sure if it's in the same module as the yaw sensor which is located under the front center seat or console depending on your truck.
Old Sep 13, 2017 | 03:22 AM
seville009's Avatar
seville009
Do you have the pitch display (accessed in the left hand steering wheel menu)? Wondering if that works off the same sensor snd if do, if called up the fisplay will show you if the pitch looks about right (ie: if the display shows you're still on an incline even though you've flattened out)
Old Sep 13, 2017 | 06:06 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Question ?
are you Sure you have the Hill sensor device.
I am not aware of the 2011-2012 "XL" having it as an option . "XLT" and up did.
mine does not have it.. but have power window, Cruise, trailer tow package, E-Locker, Power Mirrors.
Old Sep 13, 2017 | 11:56 AM
thomabb's Avatar
thomabb
No display. I have the XL IP.
Old Sep 13, 2017 | 11:58 AM
thomabb's Avatar
thomabb
Originally Posted by Chuck's First Ford
Question ?
I have it. I can watch the trailer brake display go to max output when I stop on a hill. The truck does not roll back. The hill start assist is listed on the build sheet.
Old Sep 13, 2017 | 12:01 PM
thomabb's Avatar
thomabb
You know, there is a box mounted under the driver's seat. I wonder...
W7PSK
6.7L Power Stroke Diesel
Jan 28, 2016 11:41 AM
Talyn
17
Jun 19, 2011 02:06 PM
jboard
Sep 1, 2009 06:14 AM
