EGT Sensor Failure - Twice - Concern?
Old Jan 28, 2016 | 09:44 AM
W7PSK's Avatar
W7PSK
Veteran: Navy
Had CEL light and took truck to dealer and they replaced Bank 1 sensor 4, two days later, CEL again Bank 1 sensor 3.
A. Should I be concerned about something else.
B. Ive trouble shot many EGT sensors on Airplanes, and we could tell if there was a failure coming if a couple failed by testing the sensors themselves. My Service Manager told me there is no way they can check the others out. That sounds like Bull to me.
Old Jan 28, 2016 | 11:41 AM
Ford_Doctor's Avatar
Ford_Doctor
Not really bull at all. These sensors usually fail fairly rapidly and the PCM parameters that check them do a pretty good job at picking up faults using a rationality check on initial cold start, during warm-up and continuous monitor during operation. It is in all reality possible to watch the sensor voltages and temperature readings and maybe catch a sensor going a little off. With all of the times I have done this I can honestly say I have seen a sensor do this only one time. To get it to "fail" I had to begin a manual regeneration and it then went off the scale. Hopefully this answers your question - unfortunately in most instances a tech is simply not going to see anything other than a sensor that is reading way off or as we say, a hard fault. A continuous memory code is typically enough to raise suspicion about a "failing" sensor. Other than that there is no absolute test or way to predict an EGT sensor failure.
jellybean66
Mar 1, 2009 01:23 PM
V10_Cougar
Modular V10 (6.8l)
31
Sep 26, 2007 12:12 PM
69deville
3.8 & 4.2L V6
Jan 16, 2007 05:40 PM
geoaigel
1983 - 2012 Ranger & B-Series
Jan 10, 2005 10:50 AM
lds
1997 - 2003 F150
Nov 4, 2003 06:30 PM
