ECC Valve
Old Sep 11, 2017 | 09:31 PM
cmand000's Avatar
cmand000
ECC Valve
I purchased a tank without a ecc valve and after later examination I have an ecc valve on my existing tank. Is the ecc valve needed or can eliminate it? if so what is involved in eliminating it?
Old Sep 12, 2017 | 01:47 AM
matthewq4b's Avatar
matthewq4b
You just need a vented fuel cap if you eliminate it.
Old Sep 12, 2017 | 08:21 AM
cmand000's Avatar
cmand000
Ok, so now I've looked into the gas cap, is their any difference with a vented gas cap ans a emission control gas cap.
Old Sep 12, 2017 | 02:40 PM
matthewq4b's Avatar
matthewq4b
Emissions caps are not vented
Old Sep 14, 2017 | 02:50 PM
JEFFFAFA's Avatar
JEFFFAFA
You would also have to change the fuel filler neck. Vented cap mates with a vented cap filler neck. A non-vented emissions cap fits in a matching filler neck. The tangs on a vented cap are real close to the cap. The tangs on a non-vented cap are farther away from itself. So where in the filler neck those tangs grab is deeper in an emissions filler neck. Ford did this so a person couldn't put a vented cap on an emissions vehicle.
Old Sep 14, 2017 | 03:24 PM
jas88's Avatar
jas88
Also be careful of caps that say they are "vented". Mine was not. I had to fix it with a drill bit.
Old Sep 16, 2017 | 05:10 AM
rechinca's Avatar
rechinca
jas what did you do to convert the cap?
landstorm
Jan 27, 2011 10:23 AM
Furyus1
Jul 23, 2009 09:40 AM
scotty8812
1997 - 2003 F150
Mar 27, 2009 08:55 PM
themicro
Nov 16, 2006 07:55 AM
fatfenders
15
Feb 14, 2005 05:41 PM
