6.0 keeps trying my starters. Help!!!
Old Sep 11, 2017 | 02:35 PM
Miller04's Avatar
Miller04
My 6.0 keeps trying starts on a regular bases. I was told it was a week injector by mechanic so we replaced that one and bought a new starter. Within 2 days it had fried that one also. We did check batteries and they tested good even put them in another dismal and drive them for a week. Mechanic told us we need to put another injector in it. But I don't see how a injector can fry the starter.
Old Sep 11, 2017 | 03:31 PM
navistarnut's Avatar
navistarnut
Sounds like you might need another mechanic who can actually diagnose the problem.
What brand starter are you using?
Does it take a lot of cranking to start the truck?
I would ask to see some proof of injector contribution codes.
Old Sep 11, 2017 | 04:29 PM
Don Naslund's Avatar
Don Naslund
I would suspect a bad engine ground causing the starter to overheat.
Old Sep 11, 2017 | 06:13 PM
Miller04's Avatar
Miller04
I will have to check brand when I get home. When you first put it in its only takes a couple cranks to turn over. Then in a few days it will take you a few mins to turn it over. Then the next day there is no turning it.
Old Sep 11, 2017 | 06:42 PM
TooManyToys.'s Avatar
TooManyToys.
You may have a case of poor rebuilds.
Or poor ground connections (6.0s design isn't great).
Or a broken ground cable from one of the batteries.
Or a broken battery to battery cable.
But the slowly decreasing starting ability normally indicates batteries that are running down from either an internal situation or the alternator not recharging the batteries.
So another question, how far do you drive?
Old Sep 11, 2017 | 07:32 PM
Miller04's Avatar
Miller04
It's like the fuel system is losing its prime is why have to crank so long and eventually over heat the starter
Old Sep 11, 2017 | 08:00 PM
xcrsp440's Avatar
xcrsp440
How long do you keep the starter spinning when trying to start it? They get too hot if you just let them spin and spin and spin.
Give them time to cool off between starting attempts
Old Sep 11, 2017 | 09:09 PM
Miller04's Avatar
Miller04
We Do let it cool off between tries.
Old Sep 11, 2017 | 09:49 PM
TooManyToys.
Yeah, but how long do you spin the starter?
Old Sep 11, 2017 | 10:08 PM
Yahiko's Avatar
Yahiko
Time to break out the meter and do a voltage drop test on the cables.
Both cables.
Here is a good how to video.
Old Sep 12, 2017 | 10:48 AM
TooManyToys.
I'm more of a fan of using an ammeter, but that's me.
There's a lot of info missing before this situation gets solved.
Old Sep 12, 2017 | 01:33 PM
Don Naslund
If you are doing long cranks to start (over 15 seconds), you may have a high oil pressure problem.
Old Sep 12, 2017 | 01:34 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
^^^ beat me by a minute!
The HPO system, not the fuel system. The fuel system will prime and purge itself without cranking at KOEO while the fuel pump is running. If your truck isn't starting within 8-10 seconds you have a bigger problem than a single injector or the starter. Could be injector related, or it could be a dozen other things. Diagnosing the no-start should be the priority so that you don't have to run the starter longer than the few seconds starting should take.
pat420swed
20
Oct 10, 2015 09:56 AM
npccpartsman
Jun 30, 2013 02:52 AM
wyo307
Oct 27, 2012 02:41 PM
redbug
15
Oct 3, 2009 04:49 AM
toolfan
May 10, 2005 04:28 PM
