Hot wire
Old Sep 9, 2017 | 01:05 PM
KWDAILYD's Avatar
KWDAILYD
Hot wire
Has anyone accessed a key on hot source under the hood?
Old Sep 9, 2017 | 01:10 PM
wb6anp's Avatar
wb6anp
Yes, I have, I can go look but it is off my upfitter relay box. May be the same wire if you don't have the box though. Will look when I get home. unless some one else posts.
Old Sep 9, 2017 | 04:31 PM
KWDAILYD's Avatar
KWDAILYD
Thanks. I have the upfitter switches and box. I don't want to hook it to an upfitter switch, I'm looking for something to tap into that will be hot only when the ignition is on. At least that's what I'm hoping to do.
Old Sep 9, 2017 | 07:18 PM
wb6anp's Avatar
wb6anp
Green/white stripe is switched hot, I have my dash cam hooked to it. It is blunt end cut in the upfitter harness
Old Sep 10, 2017 | 10:11 AM
KWDAILYD's Avatar
KWDAILYD
I will check that out today, thanks.
gascan
Dec 27, 2016 06:33 PM
ggadwa
6.7L Power Stroke Diesel
Apr 17, 2013 11:20 AM
JRS2
Jan 11, 2009 04:41 PM
Lucy's Driver
Aug 4, 2008 12:01 PM
F250tuff
Dec 28, 2007 11:17 PM
