If the temp sensor is bad the gauge on the dash will read either full hot or full cold. If it's reading right the sensor is fine.
On the 2-3 shift SS-B is releasing the overdrive clutch while SS-C is applying the intermediate clutch. I'd lean towards a problem with SS-C because SS-B also applies the overdrive clutch for both the 1-2 and 5-6 shifts.
Replacing all of the solenoids isn't a bad idea. Find out what that costs and decide.
Yes, the 5R110W is really a 6 speed transmission, but it only uses 5 forward gears at a time. The transmission normally shifts 1 2 3 5 6. In very cold weather, it shifts 1 2 3 4 6.
ive had a couple ford techs tell me funky shifts could be a symptom of the TFT sensor going.. usually the shift problems happen at specific temp ranges... for instance when i was diagnosing my shift problem it was only happening when cold i kept having delay shifts if i had to get on it before the tranny warmed up.. truck would act like you shifted it into neutral between every shift.. once the tranny warmed up the problem went away.. since replacing the TFT in mine this problem has gone away... havent had any winter cold temps yet though to be 100% since i did it.. so will see when winter comes.. but i was having the same problem even during the summer temps just about every morning...
but to me yalls problems sound like theyre coming from a completely different source there...
thats the dumbest thing I've ever heard. Not toward you Redford, but towards FoMoCo. Why would it be called a 5 speed if it has 6 forward ratios?
I struggle to believe this. Maaaaaaaark?
I had asked Mark about this at one point. Below, find a brief summary of my question and his response. I hope he doesn't mind me reprinting this here to save him from rewriting it. Apparently, temperature has a strong effect on how fast the different clutches can engage. In short, one shift pattern is slightly more efficient, but can't be used if the temperature of the transmission fluid is not favorable.
Quote:
Originally Posted by Wambo Very interesting stuff regarding the 3-5 shift. 30 ms shift time seems remarkably quick for a truck!
>>...small window of vehicle speed that it can downshift from 6th gear to 4th gear instead of 5th gear. This was done to give a bit more acceleration at the speed.
The shift time is about 0.400 sec. The two clutches have to complete what they are doing within 0.030 sec of each other. If the intermediate finishes releasing 0.100 seconds before the direct is completely applied the engine speed will flare. If the direct finishes applying before the intermediate has released, all parts of the gearset are held from rotating. This means the output shaft stops turning RIGHT NOW and so do the rear wheels.
of what ive read elsewhere the only time all the gears come into play is when the tow/haul mode is engaged which is only really to help relieve the loaded stress off the forward parts of the drivetrain.. (IOW your engine)... during normal driving the extra gears not necessary as the stresses are minimal.. many mfgs do this for similar reasons with AT even when not placed in a truck... accelerate hard enough in a small car itll shift through the first couple gears but if you let off and just cruise suddenly itll just skip the remaining gears and go to the last 1/2 depending on how its programmed..
as to why FMC labeled it a 5 speed when theres really 6 i couldnt say for sure... but anywhere else you look it comes up as a 6 speed tranny..
It's true. It is a five speed transmission with six forward ratios.
The transmission is really a two speed direct and overdrive transmission in front of a three speed transmission.
First gear is both transmissions in low gear, 3.11:1 ratio.
Second is the front in overdrive and the rear in first, 0.71 x 3.11 = 2.2:1
Third is the front back in low and the rear in second, 1.0 x 1.54 = 1.54:1
Fourth is the front in overdrive and the rear in second, 0.71 x 1.54 = 1.09:1
Fifth is the front in low and the rear in third, 1 x 1 = 1:1
Sixth is the front in overdrive and the rear in third, 0.71 x 1 = 0.71:1
As you can see fourth and fifth are almost the same ratio. So it NEVER uses both fourth and fifth. When it is below 0°F it shifts 1-2-3-4-6. Above 0°F it shifts 1-2-3-5-6. We changed it below 0°F because we couldn't make the 3-5 shift work right when it was cold.
As noted above there is a small speed window where it can downshift from 6th to 4th, instead of 6th to 5th.
That's not true at all. It uses the same sequences I mentioned above in or out of tow/haul.
Because it only uses five ratios. It never uses all six. Ever.
reading that makes it sound like it works like the tractor trailer rigs tranny with their hi-lo configurations on gears..
