E4od Swap
Old Oct 28, 2017 | 10:21 AM
  #46
rla2005's Avatar
rla2005
Originally Posted by fishfreak101
All of the sudden I just heard a bunch of crunching, clicking, and grinding. No park, no drive no reverse, I'm stuck in neutral, ( all I can hope now is that I'll get my money back. I'm about ready to give up on this thing...
Looks more like a transfer case let go to me.
Old Oct 28, 2017 | 03:00 PM
  #47
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
I was dring the truck to school to test the vss and timing in auto and all of the sudden the scrap yard transmission I just put on had 100k on it and just had a huge mechanical failure while driving it, it's like it just slammed into park on its own. All of the sudden I just heard a bunch of crunching, clicking, and grinding. No park, no drive no reverse, I'm stuck in neutral, ( all I can hope now is that I'll get my money back. I'm about ready to give up on this thing...
Diagnose it before you give up on it. ... or throw parts at it.
Old Oct 28, 2017 | 04:24 PM
  #48
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Almost certainly that's the transfer case that failed, not the transmission.
Old Oct 31, 2017 | 02:31 PM
  #49
fishfreak101's Avatar
fishfreak101
luckily all of you guys were right, somehow the transfer case was in between 4h and neutral so the indicator light showed 2h. It needed almost 4 quarts of fluid and, good as new. Since then I have tested the TPS for continuity and it had no gaps seemed alright, what's next
Old Nov 2, 2017 | 12:20 PM
  #50
timbersteel's Avatar
timbersteel
The transfer case was empty of fluid? Now it's working?
Are you asking what's next in line for troubleshooting the transmission?
Old Nov 2, 2017 | 12:50 PM
  #51
HardScrabble
, good as new.
This is wishful thinking.
Remember, I'm pulling for you. We're all in this together.
If it ain't broke, you're not trying hard enough.
Old Nov 5, 2017 | 12:16 PM
  #52
fishfreak101
Yeah the transfer case was almost empty, I'm asking what the next step for the surging issue is.Thanks
Old Nov 5, 2017 | 12:22 PM
  #53
fishfreak101
Yeah I'm sort of waiting for the T-Case to die but it seems alright and I have another one on hand right now, kust tring to figure out what the next step for diagnosing what the surging is, Just a recap there is a new E4od, e4od harness, vss, plugs, wires, and distributor cap. When I tested the TPS voltage was between .7 and 4.7 volts and had no gaps, the fuel pressure checks out. Right now codes include 172 (running lean). Could a lack of egr cause a lean system.
Old Nov 14, 2017 | 12:51 PM
  #54
fishfreak101
Everyone out of ideas? Could one bad fuel pump still mess up fuel delivery on a dual tank setup?
Old Nov 14, 2017 | 01:29 PM
  #55
Mark Kovalsky
One of my all time favorite TV shows! I even went to Toronto a couple times to see it filmed. I was in the audience for a Possum Lodge meeting at one of those that I attended.
Yes, it could.
Old Nov 14, 2017 | 01:30 PM
  #56
Olds64's Avatar
Olds64
Fish, I read through the entire thread. It's a bummer you've been fighting this problem.
Have you checked the condition of both of your fuel pumps? You should hear them prime the system when you turn the key to the "run" position. If you can't hear them get a buddy to help why you lie under the tanks and your buddy cycles the key.
You can also check for 12V ignition at the fuel pumps. If the pumps are in the tank you should be able to probe the 12V ignition wire going to the top of the tanks. I'm just not sure what color the wire is.
You mentioned the EGR has been deleted. Why? This almost certainly will cause drivability problems. Is this something you can restore to OE condition easily? The only reason I would delete EGR is if it is an older truck with a carburetor.
osu711
Apr 13, 2014 12:51 PM
jimboza
Apr 13, 2004 01:40 PM
jimboza
Apr 13, 2004 12:44 PM
