E4od Swap
Old Sep 27, 2017 | 08:30 AM
fishfreak101's Avatar
fishfreak101
Originally Posted by mrollings53
I'd use a transmission jack with the transmission properly secured to it; then pry between the flex plate, and torque converter with a 3 foot pry bar. Place a 2x4 between the valve covers, and the firewall to keep the motor from rocking back. You'll want to support the motor anyways from shifting with the transmission removed. If you don't have a transmission jack use pallets to support the transmission; you want it to move aft not fall.
You removed the cross member too, right?
Yeah I removed the crossmember, I'll try the prybar
Old Sep 28, 2017 | 07:42 PM
fishfreak101
Seems like I've tried just about everything. I'm going to try using a cutting wheel around the flange of the bell housing.
Old Sep 29, 2017 | 06:16 AM
jtmalott's Avatar
jtmalott
I would not recommend that, sounds like disaster waiting to happen. Especially if you are anywhere near that thing when it let's loose, your gonna find yourself between pinch points with a high rpm death wheel in your hand. Anyways, cutting wheels don't do too good on aluminum.
Take a close look at everything, something is holding you up, and it may be just rust and the bell housing is stuck to the block or the studs. Are you sure all of the bolts are out and the heads of the bolts? If so, support the motor, and take a jack to the tail end of the trans and work it up and down. Be careful and expect it to break loose at any time. Soak that thing in penetrating fluid and just keep working it. Stay safe man.
Old Sep 29, 2017 | 10:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Work it side to side, too. Push sideways on the rear of the trans. You're most likely fighting corrosion on both the alignment dowels and the broken bolts.
Old Sep 29, 2017 | 01:20 PM
GoinBoarding's Avatar
GoinBoarding
I agree with Mark. The leverage by working the rear of the trans should help. The dowels are a tight fit. Broken bolts means plenty of corrosion. Might really have to reef on it. If there's no fuel spilled, and you can safely do this, a map gas torch into the holes of the bell housing bolts could help.
Old Oct 1, 2017 | 08:31 PM
raystankewitz's Avatar
raystankewitz
Just my thoughts and experiences
Did you remove the starter? The block plate is held by the starter that is bolted to the transmission. That would prevent removal, since it's behind the flexplate. Don't ask how I know.
Old Oct 3, 2017 | 11:26 PM
fishfreak101
So in a process of cutting and chipping away chunks of the bell housing I finally got the transmission out. Now it appears that tith the transmission out I may have access to the engine oil pan. Does anyone know if I'd be able to replace the engine oil pan without lifting the engine, but with the transmission out?
Old Oct 4, 2017 | 10:39 AM
Conanski's Avatar
Conanski
Not likely, the oil pump and pickup tube extend to the bottom of the pan so the pan has to drop down enough for you to reach in and disconnect those items.
Old Oct 17, 2017 | 02:42 PM
fishfreak101
I finally swapped the transmission, and it fixed nothing. The same issue persists, does this mean it is definetely the wiring to the solenoid pack? If so would this be correct? https://www.summitracing.com/parts/msd-2776/all
Old Oct 17, 2017 | 04:28 PM
Mark Kovalsky
It means it is something outside of the transmission. The first thing to do is to check for codes. Without the codes all anyone can do is throw parts at it.
Old Oct 17, 2017 | 04:30 PM
jtmalott's Avatar
jtmalott
Bro....
that sucks, and now you don't even have the old as a spare. Good luck
Old Oct 17, 2017 | 05:52 PM
fishfreak101
KOER codes include 172, 538, 536, 632, and 50
Old Oct 17, 2017 | 09:45 PM
  #28
Mark Kovalsky
50 isn't a valid code. It's missing a digit.
Old Oct 19, 2017 | 07:04 PM
  #29
fishfreak101
I put in a new wiring harness and the problem still persists.
Old Oct 19, 2017 | 07:45 PM
  #30
Mark Kovalsky
What wiring harness? The entire vehicle harness? The VSS harness? The transmission harness? The internal transmission harness? The engine harness?
