Tranny Swap
Old Apr 13, 2004 | 10:05 AM
jimboza's Avatar
jimboza
Question Tranny Swap
Does anyone know of a problem swapping a 97 E4OD into a 94? (F150 crew 351W 2WD) Thanx, Jim
Old Apr 13, 2004 | 11:06 AM
fordberg's Avatar
fordberg
Should be a good swap. I posted once how I changed mine but I can't figure out how to show you where it is. Had a couple cool tricks on bolt access.
Old Apr 13, 2004 | 12:10 PM
tdmack's Avatar
tdmack
I've been looking for overhaul info on the E4OD. Haven't seen anything that talkes about differences other then an "upgrade" kit if you want to upgrade an early E4OD to a 96. The 96 must be better somehow.
Old Apr 13, 2004 | 12:15 PM
fordberg's Avatar
fordberg
I have read that early E40D had problems and that somewhere in the early 90s Ford fixed them.
Old Apr 13, 2004 | 12:44 PM
tdmack's Avatar
tdmack
There is a zip file about the E4OD talked about in the tranny forum. I think "dieselzen" has the file. I can't e-mail him yet but you might if you have met the minimum 15 posts.
If you can e-mail him, see if he'll mail the .zip to me as well.
