transfor case help
Old Sep 8, 2017 | 03:01 PM
  #31
somethingclever's Avatar
somethingclever
Originally Posted by lakequ
i am working with a married set up and i do beleve that that 77 has a married set up
based on the picture, and in stock configuration, it has a divorced setup.
i got another question will a trans off of a 460 fit on a 351
it will fit a 351M engine but not a 351W.
Old Sep 8, 2017 | 07:53 PM
  #32
lakequ's Avatar
lakequ
do all 1977 trucks have a divorced set up
Old Sep 8, 2017 | 09:54 PM
  #33
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do all 1977 trucks have a divorced set up?
No.
1977 F250 4WD's (High Boys) before serial number Y20,001 have a divorced transfer case and in-cab fuel tank.
1977 F250 4WD's from serial number Y20,001, 1978/79 F250 4WD's are not High Boys, have a married transfer case, no in-cab fuel tank.
Serial number is the last 6 digits of the VIN
Old Sep 13, 2017 | 10:35 AM
  #34
lakequ's Avatar
lakequ
the truck has no vin so the next easyest way to tell is by the gas tank correct? if it has the in cab tank it a highboy/divorced set up
if it has the behind cab tank (non highboy) it has the married set up
Thanks for the help guys
Old Sep 13, 2017 | 10:40 AM
  #35
gittinwidit's Avatar
gittinwidit
Deleted due to old message.
Old Sep 13, 2017 | 12:13 PM
  #36
somethingclever
the easiest way to tell is to look at the transfer case.
Is it attached to the trans or connected with a short drive shaft.
Old Sep 13, 2017 | 01:28 PM
  #37
lakequ's Avatar
lakequ
yeah im going to go look at it on sunday... i was trying to figure it out befor i drove down there but the guys has no idea what he has.
thanks for the help
axe_handle
Nov 7, 2009 07:21 PM
scottddove
Jul 11, 2006 11:56 AM
sigtauenus
Mar 25, 2004 08:28 PM
blueoval79
Jul 7, 2002 10:01 AM
CJ
Oct 22, 1999 06:58 PM
