transfor case help
Old Sep 8, 2017 | 08:27 AM
lakequ's Avatar
lakequ
ok can you swap a trans and tcase out of a 150 into a 250 is the bolt pattern the same and is there any differences?
Old Sep 8, 2017 | 08:39 AM
J ballan's Avatar
J ballan
If it's like for like I don't think they have any differences. I should ask you why you need to do this or what is the problem with yours now?
Old Sep 8, 2017 | 08:43 AM
lakequ's Avatar
lakequ
i have a 203 transfor case that is full time and i want to change it to part time so im gonna have to change the tcase
Old Sep 8, 2017 | 09:44 AM
J ballan's Avatar
J ballan
Ok gotcha, just a heads up you can get a kit for your 203 to covert it to part time and then buy some locking hubs for your front axle which you will need either way.
Old Sep 8, 2017 | 09:50 AM
lakequ's Avatar
lakequ
Where could you find those at
Old Sep 8, 2017 | 09:53 AM
lakequ's Avatar
lakequ
I have already put lock out hubs on my axle and i thought you could just put a 205 shaft in a 203 and it would change it to part time but if there is a gear kit to change it thats awsome
Old Sep 8, 2017 | 10:47 AM
J ballan's Avatar
J ballan
https://m.summitracing.com/parts/mmk-501
Not sure why my links won't work sorry.
Old Sep 8, 2017 | 11:14 AM
somethingclever's Avatar
somethingclever
There i so no bone yards that have any of that stuff around me and the 203 and 205 cases are the same size so im just going to put all 205 parts in my 203
This took 3 seconds to find:
https://columbus.craigslist.org/pts/...273899560.html
Old Sep 8, 2017 | 11:15 AM
lakequ's Avatar
lakequ
yeah im looking for a whole truck now so i can get all the parts i need looking at this one and trying to figure out if it has everything i need https://cincinnati.craigslist.org/pt...262852507.html
Old Sep 8, 2017 | 11:34 AM
somethingclever
wait, are you working on a divorced transfer case truck or married case?
The one in your avatar would be married.
The link you provided is for divorced.
gittinwidit's Avatar
gittinwidit
That's an excellent deal not considering logistics. You can get your $500 back just for the motor. Other valuable parts is the steering column, gages axles and even the frame is sought after. That front is disk brake if your's isn't???
Old Sep 8, 2017 | 11:43 AM
J ballan's Avatar
J ballan
If all your after is a part time transfercase the kit for a NP203 is like $47. Just saying.
Old Sep 8, 2017 | 11:44 AM
  #28
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1976: First year for power disc brakes for F100/250 4WD's.
1967/76 F250 4WD & 1977 F250 4WD before serial number Y20,001 are "High Boys."
ONLY High Boys have a divorced transfer case.
Old Sep 8, 2017 | 01:53 PM
  #29
lakequ's Avatar
lakequ
i am working with a married set up and i do beleve that that 77 has a married set up
Old Sep 8, 2017 | 02:17 PM
  #30
lakequ's Avatar
lakequ
i got another question will a trans off of a 460 fit on a 351
