NP435 rebuild kits?
Old Jul 5, 2002 | 01:49 PM
blueoval79's Avatar
blueoval79
NP435 rebuild kits?
I'm looking for a rebuild kit for my NP435. It's outta a 79 F250.
It's a 4spd. Does anyone know where i can find one and what should the kit consist of. Looking for the best rebuild kit with the most parts. I replaced the clutch, bolted the tranny up, and now the NP205 transfer case won't line up. I can't get the input shaft to line up with the hole. Did I bend the shaft taking the t-case off? I had a hard time getting the t-case off the support mount on the side of the frame. The 2 bolts that are on the side of the t-case were stripped, so i took the nut and rubber bushing off the bolt that connected the t-case mount to the frame mount. I couldn't lift if off so i used a pry bar to lift it high enough so it would clear. Did i bend the shaft, and does the rebiuld kit come with new shafts? If not where can i buy the shaft that goes into the clutch housing and the one that goes into the T-case. Sorry about all the questions but i'm still learning about this
Old Jul 6, 2002 | 07:55 AM
lee's Avatar
lee
NP435 rebuild kits?
Blue,
Not sure about your alignment problem but you should be able to get a rebuild kit from your local parts house. If not then try http://www.standardtransmission.com/ or http://www.drivetrain.com/ one of these should be able to help you. Good luck.
Lee
Old Jul 7, 2002 | 04:26 AM
karljay's Avatar
karljay
NP435 rebuild kits?
I found the parts at www.bearingssupplyco.com, they had great prices on the other parts I got for the front end, so you might be able to save a buck.
Old Jul 7, 2002 | 10:01 AM
StrangeRanger's Avatar
StrangeRanger
NP435 rebuild kits?
AK FORD GUY
24
Aug 3, 2021 08:57 PM
jlaudio_f100
Feb 28, 2010 06:01 PM
OpieCunningham
23
Oct 25, 2009 11:10 PM
SoCalDesertRider
Offroad & 4x4
Jan 30, 2005 04:16 AM
