Excursion Power Locks Will Not Move
Old Sep 20, 2017 | 11:57 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
That box next to the E-brake is your PCM. Also known as an ECM, engine computer, etc. Don't EVER mess with it while the key is in the ignition. You will incur a $1000 problem real quick.
Yes, the GEM is piggy-backed on the Central Junction Box (CJB) right above the PCM and E-brake.
Old Sep 20, 2017 | 12:03 PM
ITSOT's Avatar
ITSOT
Oh, that's all it is. ;-)
Old Sep 29, 2017 | 08:49 PM
ITSOT's Avatar
ITSOT
Fixed
Well, I needed new actuators after all.
I installed 4 new ones this evening and they all work.
Such is life.
Old Sep 30, 2017 | 12:52 PM
Oldguyfl's Avatar
Oldguyfl
That is the PCM
Originally Posted by ITSOT
So, this morning I visually checked the Maxi fuse and its contacts in the power distribution box under the hood (#102), and it seemed fine to me (as much as I could visually see). And I hit it with some contact cleaner. When I tried the locks, no change (sometimes they work but rarely; all other times they have some power but act as though they are tired, without enough power). Any suggestion on further examining the Maxi fuse?
Note that I wrote "Maxi fuse," which is the terminology used in my owner's manual. You wrote "relay." You also said "next to the underhood fuse box," and I was looking in the underhood fuse box. But, again, I was going by my owner's manual — I even searched the pdf for "lock." I want to be sure I am not missing something? Is there a relay I am missing?
I agree that it does not seem to be the actuators. After I looked for the "relay," following the instructions in the tech folder about fixing actuators, I took apart one actuator, and it looked pristine. I hit it with some contact cleaner, too, just for fun. When I put it back together, no change. I am assuming such is the case with the rest of them. This is to say, I don't think the problem is with the actuators.
If in fact this is the case, I wouldn't know where to begin troubleshooting; but I guess I would begin at the door switches and trace wires. In any case, when I went looking for my GEM (which Nicmike mentioned, and which I did not find because I didn't understand that it is on the back of my fuse panel [right???], AND I got sidetracked by what I did find), I found this "box" (pictured) to the side of the e-brake, unsecured. (I partially slid off the housing.) Any idea what this box is? Do you think it could be related to my lock issue? I tried to ensure that it was firmly seated.... No change in the locks.
One last tidbit of information: I recently tried to have the computer programmed for a spare key (at two dealers), and it was rejected (many times). One tech said he thinks there may be a wiring issue in the dash. Does this influence your trouble shooting?
Again, thanks.
turborich
Jul 25, 2008 10:51 AM
rc3
May 24, 2007 12:18 AM
LP2
May 27, 2006 12:52 PM
mwgwin
Aug 16, 2005 03:03 PM
fordfan1
Dec 15, 2003 02:19 PM
