Excursion Power Locks Will Not Move
Old Sep 5, 2017 | 01:16 PM
ITSOT's Avatar
ITSOT
So, the power locks on my 2000 Excursion (with 205000 miles) always have electric/signal to them, and occasionally will make the ****(s) go down or up (ie. lock the doors), but usually not. It seems like they are just too weak, or tired — that is, the **** will go down/up a tiny bit. I don't even know what to ask...
Anyone else with this problem?
Is there a fix that does not include replacing all the power lock mechanisms?
Is there a way to... "oil" the mechanism?
Other?
Thanks!
PS. Yes, the ***** work manually, with relative ease.
Old Sep 5, 2017 | 01:30 PM
alloro's Avatar
alloro
Could be dirty contacts in the door lock relays or a bad connection causing a voltage drop somewhere else in the circuit. I would think if the problem was with the actuators in the doors it would've started with one door then added other doors as time went on. The relays are in the relay box next to the underhood fuse box.
Old Sep 5, 2017 | 01:58 PM
ITSOT's Avatar
ITSOT
Thanks for replying!
I've only had the truck a few months; so, unfortunately, I do not know the history — the timing of their failures. BUT, the driver's door lock ALWAYS works. (And, again, the others will... every once in a while.)
Do you have any suggestion about troubleshooting?
Kindly,
Lee
Old Sep 5, 2017 | 02:04 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Keep in mind that the power locks go through the GEM module under the dash (just above the E. brake pedal). If they are moving at all, I would suggest it is time to replace them, or go to the tech folder (top of the Excursion forum) and read how many others have addressed this problem in the past.
Old Sep 5, 2017 | 02:21 PM
ITSOT's Avatar
ITSOT
Thanks Nicmike.
Being new, I cannot figure out how to search, or even find, these tech folders (though I read of them often). The closest thing I get to finding a "tech folder" is the "How To" link; but, even then I cannot find anything close to what I am looking for.
Can you do me a favor: Please find one thread, any thread, about power locks for an Ex; then paste the link into your reply; and then I will follow the folders from there.
Thanks again!
Lee
Old Sep 5, 2017 | 02:31 PM
ITSOT's Avatar
ITSOT
Never mind, Mike. I found them... by searching Google. Lol. (Wish I had thought of this sooner.)
Old Sep 5, 2017 | 02:42 PM
unleashd's Avatar
unleashd
Hope this helps
Old Sep 5, 2017 | 02:47 PM
ITSOT's Avatar
ITSOT
Argh. I wasn't looking anywhere around there; rather, I was looking at the top of the web page — "Forums," "Gallery," "Tools," "Marketplace," etc.
Thanks muchly!
Old Sep 6, 2017 | 04:07 PM
MO HUNTER's Avatar
MO HUNTER
Going to have to do this to my X as well.
By far, this is the most information I have seen on Excursions throughout my ownership of the vehicle.
Wish I would have found it sooner.
Old Sep 7, 2017 | 07:49 AM
ITSOT's Avatar
ITSOT
I found it before I bought my Ex. (In fact, it guided me in which Ex I bought.) But, I still don't use it enough. :-)
Old Sep 7, 2017 | 11:35 AM
Stewart_H's Avatar
Stewart_H
Three posts within minutes of each other, please click the edit button next time and add to your thought.
Stewart
Old Sep 7, 2017 | 02:27 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
But, Stewart, he needed to get his post count up!!!
Old Sep 7, 2017 | 03:36 PM
Stewart_H's Avatar
Stewart_H
Post count stuffing gets a person admonished through the FTE infraction system.
https://www.ford-trucks.com/site-guidelines/
2. Personal Conduct . Post language and material suitable for the home or office. Do not post foul language, racial epithets or sexually explicit content in any form. Personal attacks will not be tolerated. Posting for the purpose of gaining access to additional features of the site is not allowed.
Stewart
Old Sep 20, 2017 | 11:53 AM
ITSOT's Avatar
ITSOT
Could be dirty contacts in the door lock relays.... The relays are in the relay box next to the underhood fuse box.
So, this morning I visually checked the Maxi fuse and its contacts in the power distribution box under the hood (#102), and it seemed fine to me (as much as I could visually see). And I hit it with some contact cleaner. When I tried the locks, no change (sometimes they work but rarely; all other times they have some power but act as though they are tired, without enough power). Any suggestion on further examining the Maxi fuse?
Note that I wrote "Maxi fuse," which is the terminology used in my owner's manual. You wrote "relay." You also said "next to the underhood fuse box," and I was looking in the underhood fuse box. But, again, I was going by my owner's manual — I even searched the pdf for "lock." I want to be sure I am not missing something? Is there a relay I am missing?
I would think if the problem was with the actuators....
I agree that it does not seem to be the actuators. After I looked for the "relay," following the instructions in the tech folder about fixing actuators, I took apart one actuator, and it looked pristine. I hit it with some contact cleaner, too, just for fun. When I put it back together, no change. I am assuming such is the case with the rest of them. This is to say, I don't think the problem is with the actuators.
Could be...a bad connection causing a voltage drop somewhere else in the circuit.
If in fact this is the case, I wouldn't know where to begin troubleshooting; but I guess I would begin at the door switches and trace wires. In any case, when I went looking for my GEM (which Nicmike mentioned, and which I did not find because I didn't understand that it is on the back of my fuse panel [right???], AND I got sidetracked by what I did find), I found this "box" (pictured) to the side of the e-brake, unsecured. (I partially slid off the housing.) Any idea what this box is? Do you think it could be related to my lock issue? I tried to ensure that it was firmly seated.... No change in the locks.
One last tidbit of information: I recently tried to have the computer programmed for a spare key (at two dealers), and it was rejected (many times). One tech said he thinks there may be a wiring issue in the dash. Does this influence your trouble shooting?
Again, thanks.
Old Sep 20, 2017 | 11:55 AM
ITSOT's Avatar
ITSOT
Please see my last post. Thanks.
