93 F250 -E40D transmission problem
I have a 93 F250 with the 7.3 IDI NA motor and an E40D transmission.
Sometimes when the truck goes to shift out of overdrive it will rev up real high for 1/2 a second before going into gear. This typically happens between 40-55mph and when I am going up a hill. I have noticed that the motor will start to bog down a little bit before this happens (sound changes from the normal roar to a dull thudding and I get a small black cloud out the tail pipe).
I already put in a new tach sensor and adjusted the TPS. The OD light does not flash, and I have not noticed any other codes coming up. The OD light did flash before replacing the tach sensor.
Thanks in advance!
Thanks in advance!
Sorry I quit responding. I had a bunch of stuff come up that put this on the back burner for the past month. I did not see any other codes when I followed your procedure and went ahead with putting a sensor in this evening. I took the truck for a drive on some hills that always make it freak out, and it worked magnificently.
That said, the solution was the MLPS. Now, if I can get the miss out of the motor that showed up 2 weeks ago....
Thanks for all your help! Hopefully, your responses can help some others too!
DieselMechanic87
06-10-2014 12:01 PM
roycephus
05-26-2013 10:37 AM
