Sponsored by: Real Truck
Transfer case question
Old Sep 4, 2017 | 01:23 AM
Mfnboo's Avatar
Mfnboo
I just bought a 99 f250 super duty lariat. Bought it with a busted trans and transfer case it has the 4r100. Apparently the front drive shaft locked up going down the highway, when this happened the transfer case was obliterated into pieces and what was left of the front shaft was slapping the transmission cracking the hell out of the case.
I've got the trans being rebuilt but with no transfer case tag I have no clue as to which transfer case I need, its electronic and from what I gather on ford parts site its a np273 I believe(not 100%), but I don't know what the spline count count is and have nothing to compare as the pieces are laying on the side of some highway, Any help is appreciated. Thanks.
Old Sep 4, 2017 | 07:14 AM
HouseMouse's Avatar
HouseMouse
What I would do it.... Take the complete transfer case to a Transmission shop or an Off Road shop that works on suspensions and see what their opinion is. I'm sure someone in the field knows what you have.
Old Sep 4, 2017 | 08:16 AM
Mfnboo's Avatar
Mfnboo
basically all that was left of the case was what stayed bolted to the trans and the inner workings between that and the rear drive shaft, nothing else...
Old Sep 4, 2017 | 09:51 AM
redford's Avatar
redford
FTE Leadership Emeritus
It would be either an NP271 or an NP273, depending on whether you have manual or electric 4 wheel drive shifting.
Old Sep 4, 2017 | 06:03 PM
Mfnboo's Avatar
Mfnboo
it is electric, but what determines how many spline?
Old Sep 5, 2017 | 09:33 AM
redford's Avatar
redford
You will see various spline counts because these TCs were used in Ford, GM and Dodge trucks.
IIRC the Ford used a 31 spline input shaft, but please wait for someone to verify before you spend $$$.
Old Sep 5, 2017 | 06:10 PM
Mfnboo's Avatar
Mfnboo
thank you for the info, hopefully someone comes through, I'm ready to sell this thing lol
Old Sep 6, 2017 | 12:01 AM
dcast99's Avatar
dcast99
The trans shop can tell you the spline count. It has to match the trans output shaft.
fred2001
Nov 23, 2011 02:01 PM
mrhooie
Nov 9, 2009 05:19 PM
$Simpleman76
Apr 14, 2007 11:50 PM
lanceh13
Sep 11, 2006 01:37 PM
